On 15/02/2009 at 06:29, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5 Platform: Mac ; Language(s) : C.O.F.F.E.E ;
--------- Hi,
Does anyone know a way to include every file in a directory into the .cof-file whithout knowing the filenames?
Thanks in advance for your help, Gambetti
On 15/02/2009 at 08:34, xxxxxxxx wrote:
What kind of files? Into the same folder as the .cof file? Or into the cof code? As long as you know where they are I suppose -maybe- there should be some way but I'm not sure.
I think the include"file" function need the files placed and named beforehand. Other than that you might be able to at least read from files within the code. file->Open(fn, GE_READ); etc
Cheers Lennart
On 15/02/2009 at 15:34, xxxxxxxx wrote:
I have a directory which might contain user-generated files (like "userClass.coh") with class-declarations. I want to include those files in the header of the .cof-file on startup. So, normally i would have
> \> include 'userClass.coh'; \>
in the header, but I don't know the name yet. - This doesn't seem to work with "file->Open". And it doesn't seem to be possible to have those include-statements wrapped inside a method. - So, probably there's no solution for this.
Cheers, Gambetti
On 16/02/2009 at 02:06, xxxxxxxx wrote:
This is not possible in COFFEE. One possibility would be to write a C++ plugin which modifies the sources of the COFFEE files upon starting Cinema4D.
