On 02/02/2009 at 04:10, xxxxxxxx wrote:
--------- Hi,
in the dev-kitchen it says the license count is the part after '201', so it starts at the fourth digit.
In several posts here , it says the prefix for a multilicense bofore the actual lic-count is '20'.
So which is correct, '20' or '201' ?
thanks, Daniel
post:
http://www.plugincafe.com/forum/display_topic_threads.asp?ForumID=4&TopicID;=3691
On 02/02/2009 at 07:22, xxxxxxxx wrote:
You don't have to care about the first three digits. Just request the serial information with SERIAL_MULTILICENSE and you get a multi-license number, otherwise the serial number string is empty and you continue to request the normal Cinema single-license number with SERIAL_CINEMA4D. All that matters for multi-licences are the fourth, fifth and sixth digit for the number of licenses.
> \> SerialInfo si; \> \> GeGetSerialInfo(SERIAL_MULTILICENSE, &si;); \> \> if(si.nr.Content()) \> GePrint("multi "+si.nr); \> else \> { \> GeGetSerialInfo(SERIAL_CINEMA4D, &si;); \> if(si.nr.Content()) \> GePrint("single "+si.nr); \> } \>
On 02/02/2009 at 09:08, xxxxxxxx wrote:
Hello Matthias,
thanks for the code example.
I'm wondering now what happens if a customer got a multi license for say 10 copies of c4d.
the serial i get with the above method would probably be like this:
201010xxxxx
This means there is 10 clients that share this serial, which they get from the license server.
Thus i would have to make my plugin serials multi-licenses as well, which means i have to code into my serials how many licenses were bought.
Because if i dont, customers can use my single license for all their clients that share a c4d multi-license.
Is that correct or did i get sth wrong ?
On 02/02/2009 at 10:04, xxxxxxxx wrote:
Quote: _Is that correct or did i get sth wrong ? > > * * * _
Basically it would work like this, you request the first 11 digits of the customers multi-license. This will give you the number of Cinema4D seats. Currently there is no way to license a plugin only to a limited number of seats of the maximum number of Cinema4D seats. In your plugin check if a multi-license is avaible, if so apply your serial number rule containing the number of licenses. How you handle this in the end is up to you.
On 02/02/2009 at 11:09, xxxxxxxx wrote:
thanks, i can work sth out now.
greetings, Daniel
