Crashing duplicate script
    On 27/01/2009 at 14:26, xxxxxxxx wrote:
    Cinema 4D Version:   10
    Platform:   Windows  ;
    Language(s) :   C.O.F.F.E.E  ;   XPRESSO  ;
    Hi there!
    I've tried to write my first coffee script. I had a tutorial of Arndt von Koenigsmarck and modified it for my own purpose. But there must be a error, cause it crashes Cinema after activation.
    Here is the script I wrote:
    > main() \> { \>    if (!instanceof(op, PolygonObject)) return false; \>     \>    if(an) \>    { \>       var init_step, count; \>       init_step = hoehe/anzahl; \>       count = anzahl - 1; \>        \>       var data = new(BaseContainer); \>       data->SetData(MDATA_DUPLICATE_COPIES, count); \>       data->SetData(MDATA_DUPLICATE_INSTANCES, true); \>       data->SetData(MDATA_ARRANGE_MODE, 1); \>       data->SetData(MDATA_ARRANGE_LINEAR_PERSTEP,true); \>       data->SetData(MDATA_ARRANGE_LINEAR_USE_MOVE,true); \>       data->SetData(MDATA_ARRANGE_LINEAR_USE_MOVE_Y, true); \>       data->SetData(MDATA_ARRANGE_LINEAR_MOVE, vector(0,init_step,0)); \> \>       SendModelingCommand(ID_MODELING_DUPLICATE_TOOL, NULL,op,data,MODIFY_ALL); \> \>       op->Message(MSG_UPDATE); \>    } \>    set = false; \> }
    The script is entered in a coffee-node which is connected with xpresso-nodes on both sides for the user-datas.
    Any ideas why it crashes Cinema everytime?
    Thank you for your help.
    Best regards,
    skone
    On 27/01/2009 at 17:03, xxxxxxxx wrote:
    I am not 100%, but I think Coffee nodes are now allowed to alter the scene. Why don't you make a command plugin from your code?
    Greetings,
    Jack
    On 28/01/2009 at 00:12, xxxxxxxx wrote:
    Hi Jack,
    a command plugin is exactly what?
    Is it something like the one you describes in your wiki?
    I think I have to read the section about the different types of plugins first. ;]
    I'll inform you about my success - hopefully. :]
    Till next time,
    Skone
    On 28/01/2009 at 00:27, xxxxxxxx wrote:
    It is not allowed to alter the scene's structure (allocations, insertions, removing etc.) from within an expression. I am not what you want to to achieve but a script may be sufficient.
    cheers,
    Matthias
