Material directly into Material Manager
On 12/01/2009 at 10:02, xxxxxxxx wrote:
Cinema 4D Version: 11
Platform: Windows ;
Okay, really excited about my getting of my duff and exploring the possibility of developing my own plugin.Would like to know how (code, function, etc.) i need to use to get material to show up in the material manager directly from plugin response.
Thanks!
On 12/01/2009 at 10:52, xxxxxxxx wrote:
Not sure that I understand the question completely. You create a material using:
Material* mat = Material::Alloc();
if (!mat) // return some error
doc- >InsertMaterial(mat, NULL, FALSE);
mat->Message(MSG_UPDATE);
EventAdd();To 'attach' the material to a particular scene object, you must have a Texture tag and association:
TextureTag* ttag = TextureTag::Alloc();
if (!ttag) // return some error
op- >InsertTag(ttag);
// Set projection to relevant projection
ttag->SetParameter(DescID(TEXTURETAG_PROJECTION), GeData(TEXTURETAG_PROJECTION_UVW), DESCFLAGS_DONTCHECKMINMAX);
// Make Material<->TextureTag association
ttag->SetMaterial(mat);
ttag->Message(MSG_UPDATE);
EventAdd();
On 12/01/2009 at 10:55, xxxxxxxx wrote:
robert,
you answered my question. thanks.
On 17/01/2009 at 11:43, xxxxxxxx wrote:
Need some help...tried the code and did below:
BaseDocument *doc = GetActiveDocument(); //if(!doc) return FALSE;
BaseMaterial* mat = BaseMaterial::Alloc(Mbase);
doc->InsertMaterial(mat, NULL, FALSE);
EventAdd();Unfortunately, don't think that this is correct. When this part of the code is executed in my plugin, the application simply closes. No material, nothing.
I suspect that I am not declaring mat and doc, etc. as I am supposed to. Help.
Thanks.
On 17/01/2009 at 12:09, xxxxxxxx wrote:
You have to allocate a Material (as my code above shows). The BaseMaterial is just the base class for the instantiation you see in the document. That is, it doesn't represent a complete material that C4D can use in the document. InsertMaterial() uses an argument of BaseMaterial to allow it to support various types of material (Material, PluginMaterial for the moment).
-> you really have to complete this line otherwise doc->InsertMaterial(...) will only be executed if mat == NULL!
On 18/01/2009 at 07:46, xxxxxxxx wrote:
Good point. Yes, I was just making comment as the error response depends upon what the coder is doing. This must actually be 'return FALSE;' or something similar otherwise it reads like this, which isn't good:
if (!mat) doc->InsertMaterial(mat, NULL, FALSE);
You can go the positive route:
if (mat)
EventAdd();
On 18/01/2009 at 14:02, xxxxxxxx wrote:
holy crud! beautiful and i did not even begin to consider that if (!mat) // return some error was the culprit!
thank you!
