On 26/11/2008 at 01:02, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9.6+ Platform: Windows ; Mac ; Language(s) : C++ ;
--------- Hi,
how can one determine whether the 32bit or 64bit version of C4D is currently running?
Thanks in advance,
Andre
On 26/11/2008 at 12:34, xxxxxxxx wrote:
Sorry but I don´t quite see what you mean. If the user is running the 64-Bit version of c4d when your plugin is running, this will only work if your plugin is 64-bit too. I don´t see the sense in your question. What are you trying to achieve or what do you have in mind?
On 26/11/2008 at 16:01, xxxxxxxx wrote:
Hiho...
3D Designer, when he develops a plugin for windows, you're right because he has to develop two different version (cdl and cdl64)
But whats on Mac, there is only one file for both versions. Mailard: Sorry, I don't know too but that would a very useful function I searched too.
bye..
On 26/11/2008 at 17:26, xxxxxxxx wrote:
Although this is true for the MacOS dylib for R11, it still doesn't load all of the included versions - just the appropriate one. What the linker does in Xcode is to create a multi-lib file (there are ppc/intel/ppc64/intel-64 libs). Only the lib relevant to the processor and app mode (32/64) is loaded and registered by Cinema 4D.
But as you say, it would be nice to be able to get both the OS (which can be done: GeGetCurrentOS()), the cpu type (which can be done: GeGetByteOrder()), and the bit size (32/64) (which cannot be done directly). GetSystemEnvironmentalVariable() may be useful indirectly (?).
On 27/11/2008 at 02:36, xxxxxxxx wrote:
exactly, something like that would be the thing I'd search for too. I did not achieve anything with GetSystemEnvironmentalVariable() thus far either though.
On 27/11/2008 at 07:06, xxxxxxxx wrote:
Check for the __C4D_64BIT define.
Something like this:
> \> #ifdef \__C4D_64BIT \> GePrint("64 bit"); \> #else \> GePrint("32 bit"); \> #endif \>
On 04/12/2008 at 10:37, xxxxxxxx wrote:
Thank you a lot!
