On 23/11/2008 at 14:36, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.603 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- Hello all, I am exporting the document using a Hierarchy derivative and I am encountering an intermittent crash in hair.cdl in my Hierarchy::Do method. What happens is this: after the passed object has been checked and confirmed to be a non-null Opolygon, I place it in a temporary document and then call SendModelingCommand with MCOMMAND_TRIANGULATE. Upon making this call there is sometimes a crash with a _BugReport.txt trace that ends in hair.cdl. At that point, maybe the Hierarchy has gotten through 10 objects, and maybe it has gotten through 500 - there is no pattern that I can see yet. I have tried using any number of different options in the hair object's Generate tab (I need polygons) but it doesn't seem to make any difference (well, I haven't seen a problem when Single Object is enabled). I am even checking that the PolygonObject::GetPoint() and GetPointCount() are non-null/zero before I try to triangulate, just in case that could cause an issue. I am looking through as much of the documentation as I can and I don't see any special concerns noted for this scenario. This is happening in the context of a blocking thread, so there shouldn't be any issues there. I have not yet sent in any of the bug reports, since I am not sure if there is something I should/shouldn't be doing to cause this. Any input would be appreciated. Thanks, JD
On 24/11/2008 at 01:05, xxxxxxxx wrote:
Please post some code, thanks.
On 24/11/2008 at 14:12, xxxxxxxx wrote:
Okay, I tried to simplify this as much as possible and it turns out that it doesn't seem to be related to SendModelingCommand at all. Of course, I'm pretty much in the dark since it's not crashing anywhere inside my own code. Rather, it seems more that in the context of Hierarchy::Do, simply taking an object out of its document, then putting it back causes a crash later on. On that assumption, I tried NOT putting it in a temp document, and this has some success, but still crashes randomly in hair.cdl. So, if I can't remove/re-insert the object, and if I can't modify it while it's in its own document, then I suppose I will just have to clone it, or triangulate it manually?
#include <c4d.h> #include <c4d_symbols.h> static LONG count; class TestHierarchy : public Hierarchy { public: virtual void *Alloc(void) { return 0; } virtual void Free(void *data) { } virtual void CopyTo(void *src, void *dst) { } Bool CrashRandomlyDuringRun(PolygonObject* polyObj) { // since removing and replacing objects during // Hierarchy::Do seems to cause a crash, I // also tried without using a temp document BaseDocument* oDoc = polyObj->GetDocument(); ModelingCommandData mcd; mcd.op = polyObj; mcd.doc = oDoc; return SendModelingCommand(MCOMMAND_TRIANGULATE, mcd); } Bool CrashAtEndOfRun(PolygonObject* polyObj) { AutoAlloc<BaseDocument> tmpDoc; if (!tmpDoc) return FALSE; BaseDocument* oDoc = polyObj->GetDocument(); BaseObject* up = polyObj->GetUp(); BaseObject* pred = polyObj->GetPred(); polyObj->Remove(); tmpDoc->InsertObject(polyObj, 0, 0, 0); // no need to use SendModelingCommand here, it seems // that just removing and re-inserting the object is // enough to cause a crash at the end of Hierarchy::Run polyObj->Remove(); if (oDoc) oDoc->InsertObject(polyObj, up, pred, 0); return TRUE; } virtual Bool Do(void *data, BaseObject *op, const Matrix &mg, Bool controlobject) { if (controlobject) return TRUE; if (!(op && op->GetType() == Opolygon)) return TRUE; PolygonObject* polyObj = static_cast<PolygonObject*>(op); StatusSetText(String("processing # ") + LongToString(count++)); // this method may cause a crash //return CrashRandomlyDuringRun(polyObj); // this method will cause a crash //return CrashAtEndOfRun(polyObj); } }; #define ID_TEST 1000000 class TestCommand : public CommandData { public: virtual Bool Execute(BaseDocument *doc) { count = 0; TestHierarchy th; StatusSetText("running test..."); Bool ret = th.Run(doc, FALSE, 1.0, VFLAG_EXTERNALRENDERER, 0, 0); StatusSetText("success."); return ret; } virtual LONG GetState(BaseDocument *doc) { return CMD_ENABLED; } }; Bool RegisterTestCommand(void) { return RegisterCommandPlugin( ID_TEST, "Test", 0, "Test", gNew TestCommand); }
On 24/11/2008 at 15:32, xxxxxxxx wrote:
Looks like cloning is out too - again I am picking up a random crash in hair.cdl; here's another Hierarchy::Do method that will cause this:
virtual Bool Do(void *data, BaseObject *op, const Matrix &mg, Bool controlobject) { if (controlobject) return TRUE; if (!(op && op->GetType() == Opolygon)) return TRUE; BaseObject* clone = (BaseObject* )(op->GetClone(0, 0)); if (clone) BaseObject::Free(clone); return TRUE; }
Here's part of the trace, which looks pretty much the same as the ones I am seeing with SendModelingCommand:
Exception { ExceptionNumber = 0xC0000005 ExceptionText = "ACCESS_VIOLATION" Address = 0x0AA1F8E1 Thread = 1688 Last_Error = 0x00000000 } Call_Stacks { Call_Stack_Thread_1688 { hair.cdl: 0AA1F8E1 CINEMA 4D.EXE: 00722CE4 CINEMA 4D.EXE: 00947E2B CINEMA 4D.EXE: 00997D0C CINEMA 4D.EXE: 0094BC95 CINEMA 4D.EXE: 00997C4E CINEMA 4D.EXE: 0090EF7C CINEMA 4D.EXE: 0094BC95 CINEMA 4D.EXE: 00919F56 CINEMA 4D.EXE: 00B77386 CINEMA 4D.EXE: 00B1AA5B CINEMA 4D.EXE: 0094BD0B CINEMA 4D.EXE: 00919CA9 [my_plugin].cdl: 0B04579C C4DAtom::GetClone [my_plugin].cdl: 0B04586F TestHierarchy::Do [my_plugin].cdl: 0B25FBBD HDo [etc...]
I'm on a 3.8GHz dual Xeon running XP Pro x86 SP3 here. I'll send in some bug reports if you think this is looking like it's a Cinema issue. To clarify, I am seeing two apparently-unrelated issues: 1. remove/re-insert an object from its document in Hierarchy::Do seems to upset the internal workings of Hierarchy, causing it to crash at the end of its Run method 2. SendModelingCommand and GetClone are randomly causing crashes in hair.cdl when called in the context of Hierarchy::Do Thanks, JD
On 26/11/2008 at 02:36, xxxxxxxx wrote:
The problem is you modify the document used by the Hierarchy class. If you want to modify the polygonal object you have to insert a clone of the object into a temporary document. Here some working code:
> \> class ExampleHierarchy : public Hierarchy \> { \> public: \> virtual void \*Alloc(void) { return NULL; } \> virtual void Free(void \*data) { } \> virtual void CopyTo(void \*src, void \*dst) { } \> virtual Bool Do(void \*data, BaseObject \*op, const Matrix &mg;, Bool controlobject); \> \> Bool NoCrashAtEndOfRun(PolygonObject\* polyObj); \> }; \> \> Bool ExampleHierarchy::Do(void \*data, BaseObject \*op, const Matrix &mg;, Bool controlobject) \> { \> if(!op) return FALSE; \> \> if (controlobject) return TRUE; // this object is not visible, has been used by generator \> if (op->GetType() != Opolygon) return TRUE; // we can't use this \> \> return NoCrashAtEndOfRun(ToPoly(op)); \> } \> \> Bool ExampleHierarchy::NoCrashAtEndOfRun(PolygonObject\* polyObj) \> { \> AutoAlloc<BaseDocument> tmpDoc; \> if (!tmpDoc) return FALSE; \> \> PolygonObject \*tmpObj = NULL; \> tmpObj = (PolygonObject\* )polyObj->GetClone(COPY_NO_HIERARCHY|COPY_NO_ANIMATION|COPY_NO_BITS, NULL); \> if(!tmpObj) return FALSE; \> \> tmpDoc->InsertObject(tmpObj, NULL, NULL, FALSE); \> \> ModelingCommandData mcd; \> mcd.op = tmpObj; \> mcd.doc = tmpDoc; \> \> return SendModelingCommand(MCOMMAND_TRIANGULATE, mcd); \> } \> \> \> class MenuTest : public CommandData \> { \> public: \> virtual Bool Execute(BaseDocument \*doc); \> }; \> \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \> StopAllThreads(); \> \> ExampleHierarchy eh; \> \> return eh.Run(doc, FALSE, 1.0, VFLAG_EXTERNALRENDERER, NULL, NULL); \> } \>
Btw. your code is not only crashing with Hair but with other objects as well.
On 26/11/2008 at 06:25, xxxxxxxx wrote:
Thanks for the reply, but apparently you didn't read my last post. Your example is basically identical and it crashes too (tested on R9.603 and R11.012). As I said, the crash is random - you may get through a few test runs, but eventually it will crash. In testing, make sure your Hierarchy is not just re-iterating the same cache - simply clicking in a viewport should be enough to invalidate the cache after a successful test. Here I can generally get through two or three runs before it faults. JD
On 26/11/2008 at 06:46, xxxxxxxx wrote:
Sorry I had somehow overlooked you mentioning cloning objects.
Unfortunatly I can not confirm the crash with a cloned object. Please attach a scene if possible.
Btw, does it crash with exact the same code I provided?
On 26/11/2008 at 07:22, xxxxxxxx wrote:
Yes, it crashes with your exact code cut & pasted just to avoid any small difference. However, at this time I am only interested now in finding out why GetClone has an issue, so I prefer to remove any code related to SendModelingCommand - there should be no reason to think it will present any problem once I can actually get a clone of the object without crashing. I'm not sure how to attach a file on this forum, but it is easy to duplicate the test document I'm using:
If you still can't get it to crash, I'll have to go through and check my compiler/linker settings once again - are you aware of any in particular which might cause an issue? JD
