On 22/11/2008 at 14:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9-11 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- So, how would I go about making my CustomDataType know about its CustomGui and vice versa?
These are added via ELEMENTID id { CUSTOMGUI xxx } in the .res file.
I'd kill for a 'simple' *full* example in the spirit of the CUSTOMDATATYPE_SPLINE (with or without the Spline library accessibility) to understand the requirements and complexities of doing this rather than groping endlessly in the dark murkiness. I have a deep feeling that endless groping is what leads to unstable/crashy code (since there must be correct ways and incorrect ways to do this stuff). If I have to guess or use what might be considered improper methodologies, I can't be held responsible.
On 23/11/2008 at 03:44, xxxxxxxx wrote:
I assume you don´t need to specify the customgui in the resource files. The customdatatype should know about it as it simply belongs to it.
All you need to do is
YOURDATATYPEID id {Parameters}
Or do you mean something else? What are you trying to achieve?
On 23/11/2008 at 04:55, xxxxxxxx wrote:
You need to overload GetProperties()and GetResourceDataType(LONG*& table) of your CustomGuiData and your CustomDataTypeClass. Also return the string for the resource files in GetResourceSym() for your custom data type and your cusom gui.
This stuff is best explained in a full example. I am currently working on one and hope I can post something this week.
On 23/11/2008 at 09:50, xxxxxxxx wrote:
Here is some code and such so far (it's a lot). Problem is that I don't quite understand GetProperties() or GetResourceDataType() enough. GetProperties() looks to just specify variable configuration flags of the customgui/customdatatype - I don't need those really.
This is the Description Resource for the plugin object using the customgui/customdatatype (I was led by the docs to believe that the ELEMENTID and CUSTOMGUI should be the same name specified in GetResourceSym() for these) :
> CONTAINER Omagnetudezone \> { \> ... \> GROUP ID_OBJECTPROPERTIES \> { \> ... \> KDZFALLOFF MAGNETUDE_ZONE_GRAPH { CUSTOMGUI KDZFALLOFFGRAPH; } \> } \> }
Here's the header for the customgui/customdatatype (note: I've omitted the GeUserArea as this code isn't relevant for our purposes) :
> //////////////////////////////////////////////////////////////// \> // KDZ_Falloff.h \> //////////////////////////////////////////////////////////////// \> // CustomDataType/CustomGui KDZ_Falloff \> //////////////////////////////////////////////////////////////// \> // V0.1 2008.11.18 Robert Templeton \> //////////////////////////////////////////////////////////////// \> #ifndef \_KDZ_FALLOFF_H\_ \> #define \_KDZ_FALLOFF_H\_ \> \> // Includes \> #include "c4d.h" \> #include "Dkdzfalloff.h" \> \> // Plugin IDs \> // - KDZFalloffGuiData Plugin ID \> const LONG CUSTOMGUI_KDZFALLOFF = 1023308L; \> // - KDZFalloffDataTypeClass Plugin ID \> const LONG CUSTOMDATATYPE_KDZFALLOFF = 1023271L; \> \> \> // CustomDataType ============================================================= \> // CLASS: KDZFalloff \> class KDZFalloff : public iCustomDataType<KDZFalloff> \> { \> LONG type; // Spline type (see Dkdzfalloff.h) \> LONG count; // Number of spline points \> Vector\* points; // Spline points: 'z' is ignored \> \> public: \> KDZFalloff(); \> ~KDZFalloff(); \> KDZFalloff(const KDZFalloff& rhs); \> KDZFalloff& operator=(const KDZFalloff& rhs); \> operator GeData() const \> { \> return GeData(CUSTOMDATATYPE_KDZFALLOFF, \*this); \> } \> Bool Init(); \> Bool CopyTo(KDZFalloff\* dest); \> Bool Read(HyperFile\* hf); \> Bool Write(HyperFile\* hf); \> LONG GetType() const; \> LONG GetCount() const; \> Vector GetPoint(const LONG& index) const; \> Vector\* GetPoints() const; \> void SetType(const LONG& t_type); \> void SetCount(const LONG& t_count); \> void SetPoint(const LONG& index, const Vector& pt); \> }; \> \> // CLASS: KDZFalloffDataTypeClass \> class KDZFalloffDataTypeClass : public CustomDataTypeClass \> { \> INSTANCEOF(KDZFalloffDataTypeClass,CustomDataTypeClass) \> \> public: \> LONG GetId(); \> CustomDataType\* AllocData(); \> void FreeData(CustomDataType\* data); \> Bool CopyData(const CustomDataType\* src, CustomDataType\* dst, AliasTrans\* aliastrans); \> LONG Compare(const CustomDataType\* d1, const CustomDataType\* d2); \> Bool WriteData(const CustomDataType\* t_d, HyperFile\* hf); \> Bool ReadData(CustomDataType\* t_d, HyperFile\* hf, LONG level); \> CHAR\* GetResourceSym(); \> //CustomProperty\* GetProperties(); \> void GetDefaultProperties(BaseContainer& data); \> Bool \_GetDescription(const CustomDataType\* data, Description& desc, LONG& flags, const BaseContainer& parentdescription, DescID\* singledescid); \> Bool GetParameter(const CustomDataType\* data, const DescID& id, GeData& t_data, LONG& flags); \> Bool SetDParameter(CustomDataType\* data, const DescID& id, const GeData& t_data, LONG& flags); \> Bool GetEnabling(const CustomDataType\* data, const DescID& id, GeData& t_data, LONG& flags, const BaseContainer\* itemdesc); \> }; \> \> // CustomGui ================================================================== \> // CLASS: KDZFalloffGui \> class KDZFalloffGui : public iCustomGui \> { \> INSTANCEOF(KDZFalloffGui,iCustomGui) \> \> private: \> BaseContainer m_settings; \> // Pointer to CustomDataType data class (no good) \> KDZFalloff\* falloff; \> \> public: \> KDZFalloffGui(const BaseContainer& settings, CUSTOMGUIPLUGIN\* t_plugin); \> ~KDZFalloffGui(); \> // iCustomGui \> LONG CustomGuiWidth(); \> LONG CustomGuiHeight(); \> void CustomGuiRedraw(); \> Bool SetDefaultForResEdit(); \> Bool SetData(const TriState<GeData>& tristate); \> TriState<GeData> GetData(); \> // GeDialog \> Bool CreateLayout(); \> Bool InitValues(); \> LONG Message(const BaseContainer& msg, BaseContainer& result); \> Bool Command(LONG id, const BaseContainer &msg;); \> }; \> \> // CLASS: KDZFalloffGuiData \> class KDZFalloffGuiData : public CustomGuiData \> { \> INSTANCEOF(KDZFalloffGuiData,CustomGuiData) \> \> public: \> LONG GetId(); \> CDialog\* Alloc(const BaseContainer& settings); \> void Free(CDialog\* dlg, void\* userdata); \> CHAR\* GetResourceSym(); \> LONG GetResourceDataType(LONG\*& table); \> }; \> #endif // \_KDZ_FALLOFF_H\_ \>
And, finally, here's the source (omitting the GeUserArea code) :
> //////////////////////////////////////////////////////////////// \> // KDZ_Falloff.cpp \> //////////////////////////////////////////////////////////////// \> // CustomDataType and CustomGui KDZFalloff \> //////////////////////////////////////////////////////////////// \> // V0.1 2008.11.18 Robert Templeton \> //////////////////////////////////////////////////////////////// \> \> // Includes \> #include "KDZ_Falloff.h" \> \> // Maximum number of spline points \> const LONG MAX_KDZPOINTS = 128L; \> \> // METHODS: KDZFalloff =============================================================================================================== \> // Constructor \> //\*---------------------------------------------------------------------------\* \> KDZFalloff::KDZFalloff() \> //\*---------------------------------------------------------------------------\* \> { \> type = KDZ_FALLOFF_TYPE_CONTINUOUS; \> count = 0L; \> points = NULL; \> } \> // Destructor \> //\*---------------------------------------------------------------------------\* \> KDZFalloff::~KDZFalloff() \> //\*---------------------------------------------------------------------------\* \> { \> bDelete(points); \> } \> // Copy Constructor \> //\*---------------------------------------------------------------------------\* \> KDZFalloff::KDZFalloff(const KDZFalloff& rhs) \> //\*---------------------------------------------------------------------------\* \> { \> if (this == &rhs;) return; \> // Copy Data \> type = rhs.type; \> count = rhs.count; \> if (!points) points = bNew Vector[MAX_KDZPOINTS]; \> if (!points) \> { \> count = 0L; \> return; \> } \> if (!count) return; \> CopyMem(rhs.points, points, sizeof(Vector)\*MAX_KDZPOINTS); \> } \> // Copy Assignment Operator \> //\*---------------------------------------------------------------------------\* \> KDZFalloff& KDZFalloff::operator=(const KDZFalloff& rhs) \> //\*---------------------------------------------------------------------------\* \> { \> if (this == &rhs;) return \*this; \> // Copy Data \> type = rhs.type; \> count = rhs.count; \> if (!points) points = bNew Vector[MAX_KDZPOINTS]; \> if (!points) \> { \> count = 0L; \> return \*this; \> } \> if (!count) return \*this; \> CopyMem(rhs.points, points, sizeof(Vector)\*MAX_KDZPOINTS); \> return \*this; \> } \> // Initialize the CustomDataType data \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloff::Init() \> //\*---------------------------------------------------------------------------\* \> { \> if (!points) points = bNew Vector[MAX_KDZPOINTS]; \> if (!points) \> { \> count = 0L; \> return FALSE; \> } \> // Initialize as continuous bell-shaped spline \> type = KDZ_FALLOFF_TYPE_CONTINUOUS; \> count = 2L; \> points[0] = Vector(0.0f, 1.0f, 0.0f); \> points[1] = Vector(1.0f, 0.0f, 0.0f); \> return TRUE; \> } \> // Copy this to 'dest' \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloff::CopyTo(KDZFalloff\* dest) \> //\*---------------------------------------------------------------------------\* \> { \> if (this == dest) return TRUE; \> // Copy Data \> dest->type = type; \> dest->count = count; \> if (!dest->points) dest->points = bNew Vector[MAX_KDZPOINTS]; \> if (!dest->points) \> { \> dest->count = 0L; \> return TRUE; \> } \> if (!count) return TRUE; \> CopyMem(points, dest->points, sizeof(Vector)\*MAX_KDZPOINTS); \> return TRUE; \> } \> // Read from C4D File \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloff::Read(HyperFile\* hf) \> //\*---------------------------------------------------------------------------\* \> { \> if (!hf->ReadLong(&type;)) return FALSE; \> if (!hf->ReadLong(&count;)) return FALSE; \> points = bNew Vector[MAX_KDZPOINTS]; \> if (!points) return FALSE; \> if (!count) return TRUE; \> Vector\* p = points; \> for (LONG i = 0L; i != count; ++i) \> { \> if (!hf->ReadVector(p)) return FALSE; \> ++p; \> } \> return TRUE; \> } \> // Write to C4D File \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloff::Write(HyperFile\* hf) \> //\*---------------------------------------------------------------------------\* \> { \> if (!hf->WriteLong(type)) return FALSE; \> if (!hf->WriteLong(count)) return FALSE; \> if (!count) return TRUE; \> if (!points) return FALSE; \> Vector\* p = points; \> for (LONG i = 0L; i != count; ++i) \> { \> if (!hf->WriteVector(\*p)) return FALSE; \> ++p; \> } \> return TRUE; \> } \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloff::GetType() const \> //\*---------------------------------------------------------------------------\* \> { \> return type; \> } \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloff::GetCount() const \> //\*---------------------------------------------------------------------------\* \> { \> return count; \> } \> //\*---------------------------------------------------------------------------\* \> Vector KDZFalloff::GetPoint(const LONG& index) const \> //\*---------------------------------------------------------------------------\* \> { \> if (index < 0L) return Vector(0.0f); \> if (index >= MAX_KDZPOINTS) return Vector(0.0f); \> return points[index]; \> } \> //\*---------------------------------------------------------------------------\* \> Vector\* KDZFalloff::GetPoints() const \> //\*---------------------------------------------------------------------------\* \> { \> return points; \> } \> //\*---------------------------------------------------------------------------\* \> void KDZFalloff::SetType(const LONG& t_type) \> //\*---------------------------------------------------------------------------\* \> { \> type = t_type; \> } \> //\*---------------------------------------------------------------------------\* \> void KDZFalloff::SetCount(const LONG& t_count) \> //\*---------------------------------------------------------------------------\* \> { \> if (t_count < 0L) return; \> if (t_count > MAX_KDZPOINTS) return; \> count = t_count; \> } \> //\*---------------------------------------------------------------------------\* \> void KDZFalloff::SetPoint(const LONG& index, const Vector& pt) \> //\*---------------------------------------------------------------------------\* \> { \> if (index < 0L) return; \> if (index >= MAX_KDZPOINTS) return; \> points[index] = pt; \> } \> \> \> // METHODS: KDZFalloffDataTypeClass ================================================================================================== \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloffDataTypeClass::GetId() \> //\*---------------------------------------------------------------------------\* \> { \> return CUSTOMDATATYPE_KDZFALLOFF; \> } \> //\*---------------------------------------------------------------------------\* \> CustomDataType\* KDZFalloffDataTypeClass::AllocData() \> //\*---------------------------------------------------------------------------\* \> { \> return gNew KDZFalloff; \> }; \> //\*---------------------------------------------------------------------------\* \> void KDZFalloffDataTypeClass::FreeData(CustomDataType\* data) \> //\*---------------------------------------------------------------------------\* \> { \> KDZFalloff\* d = static_cast<KDZFalloff\*>(data); \> gDelete(d); \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffDataTypeClass::CopyData(const CustomDataType\* src, CustomDataType\* dst, AliasTrans\* aliastrans) \> //\*---------------------------------------------------------------------------\* \> { \> KDZFalloff\* s = (KDZFalloff\* )src; \> KDZFalloff\* d = (KDZFalloff\* )dst; \> if (!(s && d)) return FALSE; \> \> if (!s->CopyTo(d)) return FALSE; \> \> return TRUE; \> } \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloffDataTypeClass::Compare(const CustomDataType\* d1,const CustomDataType\* d2) \> //\*---------------------------------------------------------------------------\* \> { \> KDZFalloff\* s = (KDZFalloff\* )d1; \> KDZFalloff\* d = (KDZFalloff\* )d2; \> if (!(s && d)) return FALSE; \> \> return 0L; \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffDataTypeClass::WriteData(const CustomDataType\* t_d, HyperFile\* hf) \> //\*---------------------------------------------------------------------------\* \> { \> if (!(t_d && hf)) return FALSE; \> KDZFalloff\* d = (KDZFalloff\* )t_d; \> return d->Write(hf); \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffDataTypeClass::ReadData(CustomDataType\* t_d, HyperFile\* hf, LONG level) \> //\*---------------------------------------------------------------------------\* \> { \> if (!(t_d && hf)) return FALSE; \> return (static_cast<KDZFalloff\*>(t_d))->Read(hf); \> } \> //\*---------------------------------------------------------------------------\* \> CHAR\* KDZFalloffDataTypeClass::GetResourceSym() \> //\*---------------------------------------------------------------------------\* \> { \> return "KDZFALLOFF"; \> } \> /\* \> //\*---------------------------------------------------------------------------\* \> CustomProperty\* KDZFalloffDataTypeClass::GetProperties() \> //\*---------------------------------------------------------------------------\* \> { \> return datatypeprops; \> } \> \*/ \> //\*---------------------------------------------------------------------------\* \> void KDZFalloffDataTypeClass::GetDefaultProperties(BaseContainer& data) \> //\*---------------------------------------------------------------------------\* \> { \> // fill default DESC_xxx values \> data.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_KDZFALLOFF); \> data.SetLong(DESC_ANIMATE, DESC_ANIMATE_ON); \> data.SetBool(DESC_HIDE, FALSE); \> data.SetBool(DESC_REMOVEABLE, FALSE); \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffDataTypeClass::\_GetDescription(const CustomDataType\* data, Description& desc, LONG& flags, const BaseContainer& parentdescription, DescID\* singledescid) \> //\*---------------------------------------------------------------------------\* \> { \> Bool res = desc.LoadDescription(GetId()); \> if (res) flags |= DESCFLAGS_DESC_LOADED; \> return SUPER::\_GetDescription(data, desc, flags, parentdescription, singledescid); \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffDataTypeClass::GetParameter(const CustomDataType\* data, const DescID& id, GeData& t_data, LONG& flags) \> //\*---------------------------------------------------------------------------\* \> { \> const KDZFalloff\* s = (KDZFalloff\* )data; \> if (!s) return FALSE; \> if (id[0].id == KDZ_FALLOFF_TYPE) \> { \> t_data = GeData(s->GetType()); \> flags |= DESCFLAGS_PARAM_GET; \> } \> return SUPER::GetParameter(data, id, t_data, flags); \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffDataTypeClass::SetDParameter(CustomDataType\* data, const DescID& id, const GeData& t_data, LONG& flags) \> //\*---------------------------------------------------------------------------\* \> { \> KDZFalloff\* s = (KDZFalloff\* )data; \> if (!s) return FALSE; \> if (id[0].id == KDZ_FALLOFF_TYPE) \> { \> s->SetType(t_data.GetLong()); \> flags |= DESCFLAGS_PARAM_SET; \> } \> return SUPER::SetDParameter(data, id, t_data, flags); \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffDataTypeClass::GetEnabling(const CustomDataType\* data, const DescID& id, GeData& t_data, LONG& flags, const BaseContainer\* itemdesc) \> //\*---------------------------------------------------------------------------\* \> { \> return SUPER::GetEnabling(data, id, t_data, flags, itemdesc); \> } \> \> \> // METHODS: KDZFalloffGui ================================================================================================== \> static LONG restypetable[] = { CUSTOMDATATYPE_KDZFALLOFF }; \> // Constructor \> //\*---------------------------------------------------------------------------\* \> KDZFalloffGui::KDZFalloffGui(const BaseContainer& settings, CUSTOMGUIPLUGIN\* t_plugin) : iCustomGui(settings, t_plugin) \> //\*---------------------------------------------------------------------------\* \> { \> m_settings = BaseContainer(settings); \> grid = NULL; \> } \> // Destructor \> //\*---------------------------------------------------------------------------\* \> KDZFalloffGui::~KDZFalloffGui() \> //\*---------------------------------------------------------------------------\* \> { \> gDelete(grid); \> } \> // iCustomGui Methods \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloffGui::CustomGuiWidth() \> //\*---------------------------------------------------------------------------\* \> { \> return 256L; \> } \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloffGui::CustomGuiHeight() \> //\*---------------------------------------------------------------------------\* \> { \> return 256L; \> } \> //\*---------------------------------------------------------------------------\* \> void KDZFalloffGui::CustomGuiRedraw() \> //\*---------------------------------------------------------------------------\* \> { \> // Update UserArea \> grid->Redraw(); \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffGui::SetDefaultForResEdit() \> //\*---------------------------------------------------------------------------\* \> { \> return TRUE; \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffGui::SetData(const TriState<GeData>& tristate) \> //\*---------------------------------------------------------------------------\* \> { \> // Never called \> KDZFalloff\* d = static_cast<KDZFalloff\*>(tristate.GetValue().GetCustomDataType(CUSTOMDATATYPE_KDZFALLOFF)); \> if (!d) { GePrint("SetData Failed!"); return FALSE; } \> if (!d->Init()) return FALSE; \> falloff = d; \> if (grid) grid->SetCustomData(falloff); \> return InitValues(); \> } \> //\*---------------------------------------------------------------------------\* \> TriState<GeData> KDZFalloffGui::GetData() \> //\*---------------------------------------------------------------------------\* \> { \> // Doesn't work \> if (!falloff) return GeData(DA_NIL); \> LONG type = falloff->GetType(); \> GetLong(KDZ_FALLOFF_TYPE, type); \> return GeData(\*falloff); \> } \> // GeDialog Methods \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffGui::CreateLayout() \> //\*---------------------------------------------------------------------------\* \> { \> GroupBegin(0L, BFH_SCALEFIT|BFV_SCALEFIT , 1L, 0L, String(""), 0L); \> { \> // Falloff Graph \> grid = gNew Falloff_UserArea(); \> if (!grid) return FALSE; \> AddUserArea(KDZ_FALLOFF_GRAPH, BFH_SCALEFIT|BFV_TOP, 256L, 256L); \> AttachUserArea(\*grid, KDZ_FALLOFF_GRAPH, 0L); \> \> // Spline Interpolation/Type \> AddComboBox(KDZ_FALLOFF_TYPE, BFH_LEFT|BFV_CENTER); \> AddChild(KDZ_FALLOFF_TYPE, KDZ_FALLOFF_TYPE_CONSTANT, String("Constant")); \> AddChild(KDZ_FALLOFF_TYPE, KDZ_FALLOFF_TYPE_LINEAR, String("Linear")); \> AddChild(KDZ_FALLOFF_TYPE, KDZ_FALLOFF_TYPE_CONTINUOUS, String("Continuous")); \> AddChild(KDZ_FALLOFF_TYPE, KDZ_FALLOFF_TYPE_BEZIER, String("Bezier")); \> } \> GroupEnd(); \> return TRUE; \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffGui::InitValues() \> //\*---------------------------------------------------------------------------\* \> { \> // Doesn't work \> if (falloff) SetLong(KDZ_FALLOFF_TYPE, falloff->GetType()); \> return TRUE; \> } \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloffGui::Message(const BaseContainer& msg, BaseContainer& result) \> //\*---------------------------------------------------------------------------\* \> { \> return SUPER::Message(msg, result); \> } \> //\*---------------------------------------------------------------------------\* \> Bool KDZFalloffGui::Command(LONG id, const BaseContainer &msg;) \> //\*---------------------------------------------------------------------------\* \> { \> // ?? No Idea why Mikael does this \> switch (id) \> { \> case KDZ_FALLOFF_TYPE: \> { \> BaseContainer m(msg); \> m.SetLong(BFM_ACTION_ID, GetId()); \> m.RemoveData(BFM_ACTION_VALUE); \> m.SetData(BFM_ACTION_VALUE, GetData().GetValue()); \> SendParentMessage(m); \> break; \> } \> } \> return TRUE; \> } \> \> \> // METHODS: KDZFalloffGuiData ================================================================================================== \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloffGuiData::GetId() \> //\*---------------------------------------------------------------------------\* \> { \> return CUSTOMGUI_KDZFALLOFF; \> } \> //\*---------------------------------------------------------------------------\* \> CDialog\* KDZFalloffGuiData::Alloc(const BaseContainer& settings) \> //\*---------------------------------------------------------------------------\* \> { \> KDZFalloffGui\* dlg = gNew KDZFalloffGui(settings, GetPlugin()); \> if (!dlg) return NULL; \> \> CDialog\* cdlg = dlg->Get(); \> if (!cdlg) return NULL; \> \> return cdlg; \> } \> //\*---------------------------------------------------------------------------\* \> void KDZFalloffGuiData::Free(CDialog\* dlg, void\* userdata) \> //\*---------------------------------------------------------------------------\* \> { \> if (!(dlg && userdata)) return; \> KDZFalloffGui\* sub = static_cast<KDZFalloffGui\*>(userdata); \> gDelete(sub); \> } \> //\*---------------------------------------------------------------------------\* \> CHAR\* KDZFalloffGuiData::GetResourceSym() \> //\*---------------------------------------------------------------------------\* \> { \> return "KDZFALLOFFGRAPH"; \> } \> //\*---------------------------------------------------------------------------\* \> LONG KDZFalloffGuiData::GetResourceDataType(LONG\*& table) \> //\*---------------------------------------------------------------------------\* \> { \> table = restypetable; \> return sizeof(restypetable)/sizeof(LONG); \> } \> \> \> // Global Registrant for KDZFalloff (CustomDataType and CustomGui) \> //\*---------------------------------------------------------------------------\* \> Bool RegisterKDZFalloff(void) \> //\*---------------------------------------------------------------------------\* \> { \> RegisterDescription(CUSTOMDATATYPE_KDZFALLOFF, "Dkdzfalloff"); \> static BaseCustomGuiLib mylib; \> ClearMem(&mylib;, sizeof(mylib)); \> FillBaseCustomGui(mylib); \> LONG info = CUSTOMDATATYPE_INFO_TOGGLEDISPLAY|CUSTOMDATATYPE_INFO_HASSUBDESCRIPTION|CUSTOMDATATYPE_INFO_UNDOSAMECUSTOMGUI; \> return InstallLibrary(CUSTOMGUI_KDZFALLOFF, &mylib;, 1000L, sizeof(mylib)) && RegisterCustomDataTypePlugin("KDZ Falloff DataType", info, gNew KDZFalloffDataTypeClass, 0L) && RegisterCustomGuiPlugin("KDZ Falloff Gui", 0L, gNew KDZFalloffGuiData); \> }
On 23/11/2008 at 21:50, xxxxxxxx wrote:
Adding the GetProperties to both seems to have worked (just added the KDZ_FALLOFF_TYPE for now).
Of course, there is no GetResourceDataType() in the CustomDataTypeClass (or iCustomDataType). But I do have GetProperties() and GetResourceSym() in both CustomGuiData and CustomDataTypeClass and GetResourceDataType() in CustomGuiData.
Now the problem is working with the non-standard spline/GeUserArea. In C4D, they use the CustomSplineKnot in which to store the points in the appropriate class - but in my case, this spline will not necessarily be C4D-like. Just need the type and the points - stored in KDZFalloff.
Also, when I change the type, C4D crashes sometimes. Probably to do with storing the KDZFalloff* and using it. See, this is where I am confused. KDZFalloff stores the spline data while the GeUserArea (attached to iCustomGui) displays it and monitors user interaction. How does one go between these? I see that the SplineData has a Messages (and Function tables - but hopefully these are only for the library access).
