On 29/10/2008 at 17:33, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11 Platform: Language(s) : C++ ;
--------- Hi!
I have a small problem with GeUserArea and GeDialog. The area is attached to the dialog and it should redraw the area up every frame. When I click the "play" button everything works fine.
But when I call "next frame" and do this step by step, the redraw fails until I click into the area or click the play button again. Does anyone know which message I have to send that the redraw will be executed in this cases too - without calculating expressions?
Thanks a lot.
On 03/11/2008 at 02:33, xxxxxxxx wrote:
Please provide some source code, thanks.
