On 23/10/2008 at 09:30, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11 Platform: Language(s) : C++ ;
--------- Hi
Can anyone help me? I created a PrefsDialog object for settings. But within PluginStart() i can't get the settings (only the default values).
It seems, they are loaded after PluginStart(). Can I change it?
Thanks and bye.
On 24/10/2008 at 02:59, xxxxxxxx wrote:
This is working fine for me, see code below.
> \> Bool PluginStart(void) \> { \> if(!RegisterMyPrefs()) return FALSE; \> \> BaseContainer wc = GetWorldContainer(); \> BaseContainer \*bc = wc.GetContainerInstance(1023052); \> //prefs are stored in a subcontainer in the worldcontainer. the subcontainer has the same ID as the pref hook \> \> if(!bc) return FALSE; \> \> if(bc->GetBool(1000)) GePrint("set"); //a Bool element in my prefs \> else GePrint("not set"); \> } \>
here the code of the pref hook and dialog
> \> #include "c4d.h" \> #include "c4d_symbols.h" \> \> #include "lib_prefs.h" \> \> \> #define MY_PREFS_ID 1023052 \> \> enum pref_ids \> { \> PREFS_ITEM1 = 1000 \> }; \> \> class MyPrefsDialog : public PrefsDlg_Base \> { \> public: \> MyPrefsDialog(PrefsDialogHookClass\* hook) : PrefsDlg_Base(DLG_MY_PREFS, hook) { } \> \> virtual void SetValues(BaseContainer \*data); \> virtual void EnableValues(BaseContainer \*data); \> virtual LONG CommandValues(LONG id, const BaseContainer &msg;, BaseContainer \*data); \> }; \> \> void MyPrefsDialog::SetValues(BaseContainer \*data) \> { \> if(!data) return; \> \> BaseContainer \*bc = data->GetContainerInstance(MY_PREFS_ID); \> if(!bc) return; \> \> SetBool(MY_PREFS_ITEM1, bc, PREFS_ITEM1); \> } \> \> void MyPrefsDialog::EnableValues(BaseContainer \*data) \> { \> if(!data) return; \> } \> \> LONG MyPrefsDialog::CommandValues(LONG id, const BaseContainer &msg;, BaseContainer \*data) \> { \> BaseContainer \*bc = data->GetContainerInstance(MY_PREFS_ID); \> if(!bc) return FALSE; \> \> switch(id) \> { \> case MY_PREFS_ITEM1: GetBool(id, bc, PREFS_ITEM1); break; \> } \> \> return TRUE; \> } \> \> \> class MyPrefs : public PrefsDialogHookClass \> { \> public: \> virtual SubDialog \*Alloc() { return gNew MyPrefsDialog(this); } \> virtual void Free(SubDialog \*dlg) { gDelete(dlg); } \> virtual void InitPrefs(BaseContainer \*bc); \> }; \> \> void MyPrefs::InitPrefs(BaseContainer \*bc) \> { \> BaseContainer defbc; \> CheckPrefsData(bc, MY_PREFS_ID, GeData(defbc)); \> } \> \> MyPrefs \*myprefs = NULL; \> \> Bool RegisterMyPrefs(void) \> { \> String name=GeLoadString(IDS_MY_PREFS); if (!name.Content()) return TRUE; \> myprefs = gNew MyPrefs; \> if(!myprefs) return FALSE; \> return myprefs->Register(MY_PREFS_ID, name, 0, 0); \> } \> \> void FreeMyPrefs(void) \> { \> if(myprefs) \> { \> gDelete(myprefs); \> myprefs = NULL; \> } \> } \>
On 24/10/2008 at 06:57, xxxxxxxx wrote:
Thanks Matthias,
do you call the register function in PluginStart()? Bye
On 24/10/2008 at 06:59, xxxxxxxx wrote:
Yes, I call the register function in PluginStart(). Just take a look at my code, it's there at the top of PluginStart()
On 24/10/2008 at 08:01, xxxxxxxx wrote:
Ooops, I did overlook that the function is PluginStart()...
Bye.
