Hidden files OSX/Windows?
On 15/10/2008 at 08:01, xxxxxxxx wrote:
Cinema 4D Version:   R11
Platform:   Windows  ;
Does the Windows OS use/create hidden files in a similar way
that OSX add .DS_Store files?
Basically I look for empty folders using BrowseFiles.
However , Cinema "see" these hidden files (in OSX at least).
Lennart
On 20/10/2008 at 05:42, xxxxxxxx wrote:
Cinema will see all files regardless of their hidden property.
Windows does not create hidden files similar to .DS_store files on the Mac.
cheers,
Matthias
On 20/10/2008 at 05:49, xxxxxxxx wrote:
I see. Thou it is my understanding the Explorer can make Desktop.ini and thumb.db files "by itself". If they are hidden or not I can't tell since I'm on mac only.
Thanks
Lennart
On 20/10/2008 at 06:08, xxxxxxxx wrote:
If I understand it right you only want to check folders that are created by yourself within the Cinema user folder. These folders will not have hidden files, don't they?
cheers,
Matthias
On 20/10/2008 at 06:17, xxxxxxxx wrote:
That is correct. No hidden files -should- be written normaly, but -if- the user should look into that folder (just because they can:) ) and move or
resize the window, a .DS_Store/Desktop.ini file will most likely be born.
Lennart
On 20/10/2008 at 06:20, xxxxxxxx wrote:
Couldn't you simply filter-out these files in your checking routine?
cheers,
Matthias
On 20/10/2008 at 06:40, xxxxxxxx wrote:
Absolutely, if I knew all the possible names they could have:)
On the Mac side, it is pretty straight forwards they all (to my knowledge)
start with a dot. I don't think that there is such a generic rule for
Windows.
Lennart
