compile errors cinema4dsdk
On 11/10/2008 at 17:38, xxxxxxxx wrote:
Cinema 4D Version: 10
Platform: Windows ;
Hi its my first try to create plugins with c++.
So i use micosoft visual studio 2005 and i have also installed the Plugin for Visual Studio 2005.NETNow if i start the cinema 4dsdk.dsw, visual studio asked me at first if i want convert the current visual c++ project format.
I chosed yes and rebuild the solution (Build configuration "Release").
visual studio returns the following error messages:
Compiling...
main.cpp
randomfalloff.cpp
datatype.cpp
vpvisualizenormals.cpp
vpreconstructimage.cpp
vpinvertimage.cpp
vpcolorize.cpp
reversenormals.cpp
liquidtool.cpp
edgecuttool.cpp
lookatcamera.cpp
simplematerial.cpp
particlevolume.cpp
mandelbrotshader.cpp
illumination.cpp
gradientshader.cpp
bitmapdistortionshader.cpp
radiosity.cpp
triangulate.cpp
spherify.cpp
Generating Code...
Compiling...
roundedtube.cpp
noiseeffector.cpp
morphmixer.cpp
gravitation.cpp
dropeffector.cpp
circle.cpp
atom.cpp
subdialog.cpp
serial.cpp
menutest.cpp
memstat.cpp
listview.cpp
layershaderbrowser.cpp
gradientuserarea.cpp
asynctest.cpp
activeobject.cpp
stl.cpp
bff.cpp
paint_saver_test.cpp
filterthreshold.cpp
Generating Code...
Compiling...
filtermatrix.cpp
blinker.cpp
Generating Code...
Linking...
Creating library .\./obj/x32/release/cinema4dsdk.lib and object .\./obj/x32/release/cinema4dsdk.exp
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterGeneratorObject(void)" (?RegisterGeneratorObject@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterRenderingTag(void)" (?RegisterRenderingTag@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterStylingTag(void)" (?RegisterStylingTag@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterVideopost(void)" (?RegisterVideopost@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterShader(void)" (?RegisterShader@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterGrassObject(void)" (?RegisterGrassObject@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterConstraintObject(void)" (?RegisterConstraintObject@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterCollisionObject(void)" (?RegisterCollisionObject@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterForceObject(void)" (?RegisterForceObject@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
main.obj : error LNK2019: unresolved external symbol "int __cdecl RegisterDeformerObject(void)" (?RegisterDeformerObject@@YAHXZ) referenced in function "int __cdecl PluginStart(void)" (?PluginStart@@YAHXZ)
cinema4dsdk.cdl : fatal error LNK1120: 10 unresolved externalsgreetz msthavoc
On 13/10/2008 at 07:37, xxxxxxxx wrote:
Which exact version of CINEMA 4D are yo using?
cheers,
Matthias
On 21/10/2008 at 01:38, xxxxxxxx wrote:
Btw. for VS2005 you should open the *.sln (solution) files and not the *.dsw files.
cheers,
Matthias
