On 30/09/2008 at 22:55, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5 Platform: Mac OSX ; Language(s) : C++ ;
--------- I have a tag plugin that sets the lokal Object Matrix during Execute() :
> ... \> op->SetMl(NewObjectMat,TRUE); \> return EXECUTION_RESULT_OK;
The expression works just fine in general.
However, as soon as I deselect all objects, or select a tag, then the object jumps back to another state (initial?).
Any idea what causes this behaviour? Do I have to commit the change in the Matrix somehow? Do I set the objcet matrix the wrong way, so it get's destoyed? NewObjectMat is created during execute from scratch.
Thanks for any helpful pointers!
Kabe
On 01/10/2008 at 12:12, xxxxxxxx wrote:
Hi Klaus,
don't see anything wrong here. I think the problem is rather how you calculate the new matrix.
Maybe it's also safer to calculate a global matrix and transform it to the object's local? Would be stupid, but you never know...
Cheers, Jack
On 02/10/2008 at 10:52, xxxxxxxx wrote:
Well, as already said... the calculation of the new matrix is correct, and the tag works just fine, as long as I don't deselect anything.
I'm creating the Matrix with
> Matrix NewObjectMat; \> \> ... \> \> NewObjectMat = MatrixRotY(d);
It seems that MatrixRotY delivers only a temporary Matrix, that is destroyed as soon as any other proces is called.
any advice?
Thanks
On 02/10/2008 at 11:15, xxxxxxxx wrote:
> Quote: __ > > * * * > > .. as long as I don't deselect anything. > > > * * *
sounds like a check for doc- >getActiveObject() is not fulfilled anymore. do you do anything if nothing is selected somewhere in your code?
your code above looks alright, i dont think there's much to be done wrong there..
> Quote: __ > > * * * > > It seems that MatrixRotY delivers only a temporary Matrix > > > * * *
i dont think this is possible.. maybe you have to do a MSG_UPDATE or sth, but thats just guessing on my side.
greetings, Daniel
On 02/10/2008 at 13:12, xxxxxxxx wrote:
Npe, it's a tag plugin, there shouldn't be a need to signal an update.
On 09/10/2008 at 07:55, xxxxxxxx wrote:
Still struggling with this. Any further ideas would be appreciated. Kind of frustrating if a plugin works fine, but the results don't "stick"...
On 21/10/2008 at 07:21, xxxxxxxx wrote:
I can not confirm this. I may need some more detailed code. You can contact me through [email protected] if it is confidential data.
