memleaks with collidercache
On 29/09/2008 at 07:17, xxxxxxxx wrote:
Cinema 4D Version:
Platform:
im using the colliderCache in my code and have problems with mem leaks (again 😉 ). the code is based on the api example.
Bool FillColliderCache(GeColliderCache& c, BaseObject* obj,BaseDocument* doc)
    ModelingCommandData md1;
     PolygonObject* poly = NULL;
     // create a CSTO'd and joined copy. this function has no mem leaks!
     BaseObject* objCopy = getPolyObject(obj,doc);
     //triangulate
     md1.op = objCopy; md1.doc = doc;
     if(!SendModelingCommand(MCOMMAND_TRIANGULATE, md1)) goto Error;
     AtomArray::Free(md1.result);AtomArray::Free(md1.arr);
     poly = (static_cast<PolygonObject*>(md1.op));
     if (!poly) goto Error;
    // Get the polygon data
     #ifdef C4D_R9
          Polygon* tris = poly->GetPolygon();
          Vector* points = poly->GetPoint();
     #else
           CPolygon* tris = poly->GetPolygonW();
           Vector* points = poly->GetPointW();
     #endif
    // Fill the cache with the tri's
    // if i comment out this block, the mem leaks are gone..
    if (c.BeginInput(poly->GetPolygonCount()) != COL_OK) goto Error;
     for (int i = 0; i < poly->GetPolygonCount(); ++i)
      if (c.AddTriangle(points[tris _.a], points[tris _.b], points[tris _.c], i) != COL_OK) goto Error;
    if (c.EndInput() != COL_OK) goto Error;
     BaseObject::Free(objCopy);
     //GeFree(points); // crash!
     //GeFree(tris); // crash!
     //BaseObject::Free(md1.op); // crash!
    return TRUE;
Error:
     return FALSE;
i thought the leaks were due to not freed points, tris and md1.op. But the problem is that cinema crashes when i try to free any of these..
When i outcomment the part were i store the tri's in the collidercache, the leaks are gone..
The collidercache itself is declared outside by autoalloc, so i assumed that all its data would be free'd automatically ?
In that regard I also trie the freePairsList() on the colliderCache, but that made no difference.
thanks,
Daniel
