On 28/09/2008 at 17:20, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.1 Platform: Windows ; Mac ; Language(s) : C++ ;
--------- Hi,
I am trying to get the points of a deformed spline here, so my plugin object can work with a deformed spline.
Everything would be so easy, if op->GetDeformCache() would not always return 0x00000000 when "op" is a SplineObject.
Now I have to use CurrentStateToObject and clone the spline including hierarchy (because if I use COPY_NO_HIERARCHY, the deformers are of course gone). The problem is: When the user puts my plugin object as a child object of the Spline, Cinema crashes. I guess, it's recursion. Sounds logical.
So my question is: How can I get the deformed points of a spline without cloning the spline's hierarchy? or How can I prevent either that the user puts my plugin object as a child under the spline, or how can I recognize if the spline is a parent of my plugin object?
There has to be a solution. But which?
Thanks for any help!!
Greetings, Jack
On 29/09/2008 at 01:08, xxxxxxxx wrote:
Quote: How can I get the deformed points of a spline without cloning the spline's hierarchy? > > * * * > > * * *
You can't at least not in GetVirtualObjects(). You have to use CurrentStateToObject with a temporary document.
> Quote: How can I pr event either that the user puts my plugin object as a child under the spline > > * * * > > * * *
You can't.
> Quote: how can I recognize if the spline is a parent of my plugin object? > > * * * > > * * *
I would say check in GetVirtualObjects() if the spline (I guess you got it from a link field) is the same as the parent of your object. I think pointer comparing should be enough.
