On 11/09/2008 at 13:28, xxxxxxxx wrote:
--------- Hi i want to do this in c++ :
i search the forum and the sdk ... but i found nothing ...
On 12/09/2008 at 08:49, xxxxxxxx wrote:
have a look at the videopost sdk examples.
On 18/09/2008 at 07:36, xxxxxxxx wrote:
Get the PluginVideoPost from the RenderData. Get the BaseContainer of the PluginVideoPost. You can access the description elements through their IDs. Set or delete the BIT_VPDISABLED bit to enable/disable the effect.
little example
> \> RenderData \*rd = NULL; \> rd = doc->GetActiveRenderData(); \> if(!rd) return FALSE; \> \> PluginVideoPost \*pvp = NULL; \> pvp = rd->GetFirstVideoPost(); \> \> if(!pvp) return TRUE; \> \> pvp->SetBit(BIT_VPDISABLED); \> \> BaseContainer \*data = pvp->GetDataInstance(); \> \> data->SetBool(VP_COMICCOLOR, TRUE); \> \> pvp->Message(MSG_UPDATE); \> \> EventAdd(); \>
