On 30/08/2008 at 14:19, xxxxxxxx wrote:
User Information: Cinema 4D Version: r10.1 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- hi there, again:) i've got my first dialog to work, now, how can i set the min and max values for a slider, so that it moves for example between 1 and 100 in 0.1 steps?
thanks in advance, ello
On 30/08/2008 at 14:22, xxxxxxxx wrote:
oh, found it... sometimes asking brings the answers SetInt(...) and such
cool
On 30/08/2008 at 14:49, xxxxxxxx wrote:
ok, but now i've got another problem.. how can i set the value of a slider from another function? say i have such a slider:
... AddStaticText(0,BFH_LEFT,0,0,cS7,0); AddEditSlider(eSlider7,BFH_SCALEFIT,100,0); SetInt(eSlider7,1,1,10000,1); ...
and i want to set eSlider7 to 200 ?
On 30/08/2008 at 15:59, xxxxxxxx wrote:
Should be the same in any dialog class method. If you need to set it from another class for some reason, add a method to the dialog class which sets this field and call that.
MyDialog::SetSlider7(var val) { SetInt(eSlider7,val,1,1000,1); }
On 30/08/2008 at 16:05, xxxxxxxx wrote:
thank you! just found it
