On 28/08/2008 at 13:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: R11 DEMO Platform: Windows ; Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- Hi. By Todays first update of R11 DEMO, the version is not longer the same as R10 DEMO.
By printing out; var version = GeGetVersionType();
I now get version 4739.
Can we assume that this will be the version number of R11 DEMO, or will it change for each update. -And- will it change if the user register for a 42 save enabled version?
Cheers Lennart
On 01/09/2008 at 10:59, xxxxxxxx wrote:
Any input on this, please.
On 01/09/2008 at 11:58, xxxxxxxx wrote:
Please check for VERSION_SAVABLEDEMO.
On 01/09/2008 at 14:38, xxxxxxxx wrote:
Just a little correction, please check for VERSION_SAVABLEDEMO and VERSION_SAVABLEDEMO_ACTIVE.
On 01/09/2008 at 14:57, xxxxxxxx wrote:
Thanks Matthias.
So will:
> if(GeGetVersionType()&VERSION;\_SAVABLEDEMO) \> println("VERSION_SAVABLEDEMO");
be enough or will I need
> if(GeGetVersionType()&VERSION;\_SAVABLEDEMO_ACTIVE) \> println("VERSION_SAVABLEDEMO_ACTIVE");
..as well for a activated DEMO? (The 42 days saveable one)
On 01/09/2008 at 14:58, xxxxxxxx wrote:
Ops, missed your last postbefore asking:)
Thanks Lennart
On 04/09/2008 at 19:22, xxxxxxxx wrote:
So, do you just check like this?:
if (GeGetVersionType()&(VERSION_SAVABLEDEMO|VERSION_SAVABLEDEMO_ACTIVE)) ...
Thanks!
On 05/09/2008 at 02:05, xxxxxxxx wrote:
Atm, I run them separate, as in my post above as I wasn't sure about using a "or" (single beam, " | ") inside a bitwise check:)
I'm also not sure how to make it work for R10 (within the same plugin) as the "SAVABLEDEMO_ACTIVE" and "SAVABLEDEMO" are not defined in R10. (I like to have the plugin to load in R10 and R11) In pre R11 only "VERSION_DEMO" is defined. Would the numeric values as seen below be safe enough?
> \> #define VERSION_CINEMA4D (1<<0) \> \> #define VERSION_BODYPAINT (1<<1) \> \> #define VERSION_NET (1<<2) \> \> #define VERSION_SERVER (1<<3) \> \> #define VERSION_DEMO (1<<4) \> \> #define VERSION_BENCHMARK (1<<6) \> \> #define VERSION_BODYPAINT2_EX (1<<7) \> \> #define VERSION_MODELER (1<<8) \> \> // 1<<9 somehow used in GeGetVersionTypeSDK \> \> #define VERSION_BPSTANDALONE (1<<10) \> \> #define VERSION_UPDATER (1<<11) \> \> #define VERSION_SAVABLEDEMO (1<<12) \> \> #define VERSION_SAVABLEDEMO_ACTIVE (1<<13) \>
On 05/09/2008 at 08:36, xxxxxxxx wrote:
I use preprocessor directives to distinguish builds for different Cinema 4D versions (inclusive). So, for this, I'm doing this (is working!) :
> BOOL network = FALSE; \> LONG vtype = GeGetVersionType(); \> if ((vtype & VERSION_SERVER) || (vtype & VERSION_NET)) network = TRUE; \> #ifdef C4D_R11 \> if (!((vtype & VERSION_DEMO) || (vtype & VERSION_SAVABLEDEMO|VERSION_SAVABLEDEMO_ACTIVE) || network)) \> { \> // serial number check \> if (!(ippSerial && ippSerial->registered)) return FALSE; \> } \> #else \> if (!((vtype & VERSION_DEMO) || network)) \> { \> // serial number check \> if (!(ippSerial && ippSerial->registered)) return FALSE; \> } \> #endif
On 08/09/2008 at 02:24, xxxxxxxx wrote:
Quote: So, do you just check like this?: > > * * * > > > if (GeGetVersionType() & VERSION_SAVABLEDEMO|VERSION_SAVABLEDEMO_ACTIVE)) > > * * *
Yes, VERSION_SAVABLEDEMO is just the demo and VERSION_SAVABLEDEMO_ACTIVE is the activated demo.
