On 28/08/2008 at 03:24, xxxxxxxx wrote:
User Information: Cinema 4D Version: r10.1 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hi again, now i am facing a strange problem concerning the userdata. i have a variable "faktor" this is to be set by the userdata: var faktor = op#ID_USERDATA:5;
println (tostring(faktor)); gives the correct value, but if i use faktor lateron for scaling an object, the objects scale is 0. if i manually set faktor in the script: var faktor = 3; // for example
than it works correctly. what could cause this behaviour?
thanks and cheers, ello
On 28/08/2008 at 03:31, xxxxxxxx wrote:
Please post some code example. Also where do you call the code from (COFFEE expression, script etc.)
On 28/08/2008 at 23:09, xxxxxxxx wrote:
thanks, its solved. for some reason, after restarting my computer the script worked. prior to the issue i had deleted a userdata field, so maybe the ID's got scrambled?
anyhow now it works...
