On 27/08/2008 at 12:58, xxxxxxxx wrote:
User Information: Cinema 4D Version: r10.1 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hi, i am currently facing a problem with creating a proper polygonflow for an object. Generally it would help me if i could see how for example the "ebenen"-object is created with c.o.f.f.e.e.
my current snippet is this, btw, the if (op#ID_USERDATA:1==1) is just a boole userdata to start the script:
\> main(doc,op) \> { \> var random = new(Random); \> random->Init(time()); \> \> if (op#ID_USERDATA:1==1) \> { \> op#ID_USERDATA:1=0; \> op#ID_USERDATA:2="Gestartet"; \> var newObj = new(PolygonObject); \> newObj->SetName("terra"); \> \> doc->InsertObject(newObj,NULL,NULL); \> GeEventAdd(DOCUMENT_CHANGED); \> \> var vc = new(VariableChanged); if (!vc) return FALSE; \> \> var cnt; \> var ok; \> var _xCnt,_yCnt,_xPos,_yPos,_vPos; \> var _p1,_p2,_p3,_p4; \> var _xMax = op#ID_USERDATA:3; var _yMax = op#ID_USERDATA:4; \> var _pNum; \> \> var pArr = new(array,_xMax*_yMax); \> \> for (_xCnt=0;_xCnt<_xMax;_xCnt++) \> { \> for (_yCnt=0;_yCnt<_yMax;_yCnt++) \> { \> cnt = newObj->GetPointCount(); \> vc->Init(cnt,cnt+1); \> ok =newObj->MultiMessage(MSG_POINTS_CHANGED,vc); \> _pNum = cnt;//_xCnt*_yMax + _yCnt; \> _xPos = (_xCnt-_xMax/2)*200; \> _yPos = (_yCnt-_yMax/2)*200; \> _vPos = 512*random->Get01(); \> newObj->SetPoint(_pNum,vector(_xPos-100,_vPos,_yPos+100)); \> } \> } \> \> for(_xCnt=0;_xCnt<_xMax;_xCnt++) \> { \> for(_yCnt=0;_yCnt<_yMax-1;_yCnt++) \> { \> cnt = newObj->GetPolygonCount(); \> vc->Init(cnt,cnt+1); \> ok =newObj->MultiMessage(MSG_POLYGONS_CHANGED,vc); \> _pNum = cnt;//_xCnt*_yMax + _yCnt;// \> _p1 = _pNum; \> _p2 = _pNum + 1; \> _p3 = _pNum + _yMax + 1; \> _p4 = _pNum + _yMax; \> newObj->SetPolygon(_pNum, _p1,_p2,_p3,_p4); \> } \> } \> var t = AllocTag(Tphong); \> newObj->InsertTag(t,NULL); \> newObj->Message(MSG_UPDATE); \> \> doc->SetActiveObject(newObj); \> op#ID_USERDATA:2+="\nFertitsch"; \> } \> } \>
but it creates a big polygon when one row is finished and the other starts.
it would be cool if someone points me to the solution thanks in advance, ello
On 28/08/2008 at 01:44, xxxxxxxx wrote:
here you go:
> \> var x = 10; //x resolution \> var y = 10; //y resolution \> \> var op = doc->GetActiveObject(); \> \> if (!op || !instanceof(op,PolygonObject)) return; \> \> var vc = new(VariableChanged); if (!vc) return; \> \> var vcnt = op->GetPointCount(); \> vc->Init(vcnt, (x+1)\*(y+1)); \> \> if(!op->MultiMessage(MSG_POINTS_CHANGED,vc)) return; \> println("points changed"); \> \> var fcnt = op->GetPolygonCount(); \> vc->Init(fcnt, x\*y); \> \> if(!op->MultiMessage(MSG_POLYGONS_CHANGED,vc)) return; \> println("polygons changed"); \> \> println("set points"); \> \> var i,j,k=0; \> for(i=0; i<(y+1); i++) \> { \> for(j=0; j<(x+1); j++) \> { \> op->SetPoint(k,vector(j\*20,0,i\*20)); \> k++; \> } \> } \> \> k=0; \> for(i=0; i<y; i++) \> { \> for(j=0; j<x; j++) \> { \> var poly = new(Polygon); \> poly->a = j+(i\*(x+1)); \> poly->b = j+(i\*(x+1))+x+1; \> poly->c = j+(i\*(x+1))+x+2; \> poly->d = j+(i\*(x+1))+1; \> op->SetPolygon(k,poly); \> k++; \> } \> } \> \> op->Message(MSG_UPDATE); \>
On 28/08/2008 at 02:04, xxxxxxxx wrote:
thank you very,very much!
best greetings, christian
