another getddescription problem
On 26/08/2008 at 05:18, xxxxxxxx wrote:
Cinema 4D Version: 10.5
Platform: Windows ;
Hello all,
I try to fill a combobox cycle in myObjectPlugin, i read a lot of tread on this issue but i can't find the correct way to add item in DESC_CYCLE container.
here my Code:_
_Bool Takemanager::GetDDescription(GeListNode *node, Description *description,LONG &flags) { if (!description->LoadDescription(1022860)) return FALSE; BaseObject * op = ((BaseObject * )node); BaseContainer * data = op->GetDataInstance(); BaseDocument * doc = GetActiveDocument(); BaseContainer group = GetCustomDataTypeDefault(DTYPE_GROUP); group.SetString(DESC_NAME, "Take Selector"); if(!description->SetParameter(DescLevel(6001, DTYPE_GROUP, 0), group, DescLevel(0))) return TRUE; BaseContainer Ctake = GetCustomDataTypeDefault(DTYPE_LONG); Ctake.SetString(DESC_NAME, "Current Take"); BaseContainer cycle ; Ctake.SetContainer(DESC_CYCLE,cycle); cycle.SetString(DESC_NAME,"test1"); if(!description->SetParameter(DescLevel(6002, DTYPE_LONG, 0), Ctake, DescLevel(6001))) return TRUE; flags |= DESCFLAGS_DESC_LOADED; return TRUE; } _]
Thanks a lot
Franz_
On 26/08/2008 at 07:03, xxxxxxxx wrote:
Ok solved
Thanks
Franz
