On 24/08/2008 at 07:37, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5 Platform: Language(s) : C++ ;
--------- Hello all, after a lot of serch, i don't understand if and how is possible store a container in a tag container. in particular in my tagplugin i have a baselist2d link and i want to store the linked element container in my tag container. can anyone help me ? thanks Franz
On 24/08/2008 at 09:22, xxxxxxxx wrote:
Get a unique plugin ID to use for the sub container and then do this:
tagBC->SetContainer(ID_MASTERSLAVE, mbc);
where 'mbc' is the linked element container. You'll need to get tagBC from the tag using:
BaseContainer* tagBC = myTag->GetDataInstance();
On 24/08/2008 at 10:49, xxxxxxxx wrote:
Thank you Robert, i'll try tonight thanks a lot Franz
On 24/08/2008 at 13:18, xxxxxxxx wrote:
ok, now my code is :
BaseContainer * Tdata = tag->GetDataInstance(); BaseList2D* item = Tdata->GetLink(IDC_TTAKEOVER_ITEM,doc,0); BaseContainer *itembc = item->GetDataInstance(); Tdata->SetContainer(ID_SUB,itembc); But, compiler tel me : 'BaseContainer::SetContainer' : cannot convert parameter 2 from 'BaseContainer *' to 'const BaseContainer &' sorry i know i am a beginner Thanks Franz
On 24/08/2008 at 14:41, xxxxxxxx wrote:
hello all, ok i find my error, * befor item in set container. Thanks for help Franz
On 24/08/2008 at 16:19, xxxxxxxx wrote:
Yes, that was it.
On 25/08/2008 at 00:41, xxxxxxxx wrote:
ok now i have a new question I read that some object in Cinema Don't store data in container (for example Olight), and i must to use Get/SetParameter to work with this object. Is there a way to collect all parameter of an object or i shoul to get/setParameter for each of this? Thanks Franz
On 25/08/2008 at 00:50, xxxxxxxx wrote:
I am not sure what you mean with collecting all paramters.
On 25/08/2008 at 00:59, xxxxxxxx wrote:
hello Matthias, Sorry My english is not very good. If Object use container i can copy all parametre with CopyTo function to another object or tag. My question is can i make somthink like this with Object like light or i must to set evry sigle parameter? Thanks a Lot Franz
