Selection Object
On 21/08/2008 at 20:59, xxxxxxxx wrote:
Cinema 4D Version: 10.5
Platform: Mac ;
Language(s) : C.O.F.F.E.E ;---------
Is it possible to restore the selection of a selection object in coffee? Ultimately, I'm trying to select a set of joints and then use the Align command. I figured it would be easier to use the selection object to pre-bundle the joints. If it's not possible to perform the restore selection, how would one go about selecting a set of objects?
On 22/08/2008 at 01:42, xxxxxxxx wrote:
You have to set the BIT_AOBJ bit. See following script, it selects all objects of a document.
\> StepThru(op) \> { \> while(op) \> { \> op->SetBit(BIT_AOBJ); \> StepThru(op->GetNext()); \> op = op->GetDown(); \> } \> } \> \> main(doc, op) \> { \> StepThru(doc->GetFirstObject()); \> } \>
cheers,
Matthias
On 22/08/2008 at 17:31, xxxxxxxx wrote:
Thank you very much Matthias, that works perfectly.
