SplineObject Problem
On 31/07/2008 at 02:16, xxxxxxxx wrote:
Cinema 4D Version:   10.5
Platform:
Hi!
I've a problem with the SplineObject. I create a spline and try to get the segments.
GetSegmentCount() returns 0.. why? When I create two "splines" in one object it returns 2.. Does anyone know?
thanks..
On 31/07/2008 at 02:44, xxxxxxxx wrote:
that´s simply the way it is. When it returns 0 it should actually return 1. It means nothing, don´t care. :) (you should however check if there is at least 1 vertex in it...just to be sure 0 means 1).
0+0 ergibt bei Cinema manchmal 1. ;-D
On 31/07/2008 at 04:00, xxxxxxxx wrote:
Hi 3DDesigner..
In c4d 0+0 is 1(sometimes?) I am happy to see, that my plugin is in a good environment.. hehe.
I wrapped this function for my python plugi, so I will fix this issue that get_segment_count() will return 1 on "0".
On 31/07/2008 at 05:57, xxxxxxxx wrote:
If you have a segment count of zero the spline object has no segment tag yet. Check the VariableTag in the docu and also this thread (it applies to C++ and COFFEE)
spline segments
cheers,
Matthias
On 31/07/2008 at 07:39, xxxxxxxx wrote:
Hi!
I have to take my hat off to you.. Thank you for the info.
bye..
