Random Position on Surface?
    On 29/07/2008 at 06:51, xxxxxxxx wrote:
    Cinema 4D Version:   10.1
    is there a good (and fast) way to get a random position on a polygon object's surface, and maybe even the surface normal at that position?
    I didn't find anything in the SDK, maybe I just don't know what to search for.
    Thanks in advance for any tipps and hints!
    Greetings,
    Jack
    On 29/07/2008 at 07:12, xxxxxxxx wrote:
    The TP node "PSurfacePosition" does exactly what I want, but I need to implement it in C++. Is there any class I could have a look at which may help me with that?
    Thanks again,
    Jack
    On 29/07/2008 at 11:56, xxxxxxxx wrote:
    OK, I already got my answer. And a pretty good one, indeed :)
    Thanks anyway.
    Jack
    On 29/07/2008 at 13:00, xxxxxxxx wrote:
    Nice to hear you found a solution. Would you mind sharing what you found out?
    cheers,
    Matthias
    On 30/07/2008 at 12:33, xxxxxxxx wrote:
    Get a random polygon from the object, weight it according to its area (to prevent resulting random positions crowding on smaller polygons).
    The use random baricentric coordinates to get a position on the triangulated polygon.
    At first I wanted to do it with a GeRayCollider shootin' random rays at the geometry, but this way is much faster and less work to implement :)
    URL=http://en.wikipedia.org/wiki/Barycentric_coordinates_(mathematics)]Wiki Link[/URL]
    Jack[
