On 18/07/2008 at 06:10, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10 Platform: Windows ; Language(s) : C++ ;
--------- Hi. Can somebody please tell me, how I can change the values in the attribut manager programmatically?
This doesn't work:
BaseContainer *data = node->GetDocument()->GetDataInstance();
data->SetReal(ASTANSATZ,0);
node->Message(MSG_UPDATE);
On 18/07/2008 at 06:14, xxxxxxxx wrote:
Well, obviously. You are getting the BaseContainer of the document not the node! Try:
BaseContainer* data = node->GetDataInstance();
instead.
On 18/07/2008 at 06:38, xxxxxxxx wrote:
Hm. There is no function GetDataInstance() in node. By the way this should happen in the Message()-function.
On 18/07/2008 at 07:30, xxxxxxxx wrote:
Sorry, you have to up-cast the node, for instance:
BaseContainer* bc = ((BaseObject* )node)->GetDataInstance();
On 18/07/2008 at 07:52, xxxxxxxx wrote:
Works fine. Thank you!
