On 11/07/2008 at 08:52, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5 Platform: Mac OSX ; Language(s) : C++ ;
--------- Hi!
I created a node-object and would like to create a small helper.
For example a circle, square like the TP Storm Generator. I thought of ObjectData, but I don't want to include it in the objectmanager.
Thanks and bye
On 11/07/2008 at 09:08, xxxxxxxx wrote:
Do you mean a 'helper' as in a visual aid in the View? You'll need to implement the SceneDraw() method I would think (similar to ObjectData::Draw()).
On 11/07/2008 at 10:54, xxxxxxxx wrote:
Hi!
Thanks! Yes, that can help me. Do I have to override this function? I try to print out something to the console i(n the function), but nothing happens.
Bye
On 11/07/2008 at 11:17, xxxxxxxx wrote:
Yes, you have to override the function and do the drawing with help of the BaseDraw instance provided. Unfortunately, I have no idea how the GvOperatorData::SceneDraw() works. If you continue to get no calls to the method, Matthias may need to chime in. GvNodeMaster::AddToDrawList() looks interesting but not much detail on how that works in conjunction with SceneDraw().
Here's the override for one of my plugin objects:
// ObjectData.Draw //*---------------------------------------------------------------------------* Bool IPPBase::Draw(PluginObject* op, LONG drawpass, BaseDraw* bd, BaseDrawHelp* bh) //*---------------------------------------------------------------------------* { if (!(op && bd && bh)) return TRUE;
// Draw 'Bone' in general if (drawpass == DRAWPASS_OBJECT) { bbc = op->GetDataInstance(); if (!bbc) return TRUE; // Draw Bone or not if (!bbc->GetBool(IPP_SHOWBONE)) return TRUE; BaseDocument* doc = op->GetDocument(); if (!doc) return TRUE; root = bbc->GetObjectLink(IPP_ROOT, doc); if (!root) return TRUE; // Show Root bones differently if (bbc->GetBool(IPP_ISROOT) || root->GetTag(ID_IPPOBJECTTAG)) { Matrix mg = bh->GetMg(); bd->SetPen(Vector(1.0f,1.0f,0.0f)); mg.v1 = Vector(epBBlen,0.0f,0.0f); mg.v2 = Vector(0.0f,epBBlen,0.0f); bd->Circle3D(mg); mg.v1 = Vector(0.0f,0.0f,epBBlen); mg.v2 = Vector(0.0f,epBBlen,0.0f); bd->Circle3D(mg); mg.v1 = Vector(epBBlen,0.0f,0.0f); mg.v2 = Vector(0.0f,0.0f,epBBlen); bd->Circle3D(mg); } else { // To avoid origin clipping of entire draw using: bd->DrawPolygonObject(bh, boneObj, DRAWPOLYOBJECT_LOCALMATRIX); boneObj->SetMg(bh->GetMg()); boneObj->Message(MSG_UPDATE); bd->DrawPolygonObject(bh, boneObj, 0L); } } // Draw Basic Data when selected else if (drawpass == DRAWPASS_HANDLES) { bbc = op->GetDataInstance(); if (!bbc) return TRUE; // Origin-EndPoint Matrix mg = bh->GetMg(); // Origin cross-hairs bd->SetPen(Vector(0.0f,1.0f,0.0f)); bd->Line3D(Vector(-lenBB, 0.0f, 0.0f)*mg, Vector(lenBB, 0.0f, 0.0f)*mg); bd->Line3D(Vector(0.0f, -lenBB, 0.0f)*mg, Vector(0.0f, lenBB, 0.0f)*mg); bd->Line3D(Vector(0.0f, 0.0f, -lenBB)*mg, Vector(0.0f, 0.0f, lenBB)*mg); // Line between Origin-EndPoint bd->SetPen(Vector(1.0f,1.0f,0.0f)); bd->Line3D(Vector(0.0f,0.0f,0.0f)*mg, epBB*mg); // EndPoint cross-hairs bd->SetPen(Vector(1.0f,0.0f,0.0f)); bd->Line3D(Vector(epBB.x-lenBB, epBB.y, epBB.z)*mg, Vector(epBB.x+lenBB, epBB.y, epBB.z)*mg); bd->Line3D(Vector(epBB.x, epBB.y-lenBB, epBB.z)*mg, Vector(epBB.x, epBB.y+lenBB, epBB.z)*mg); bd->Line3D(Vector(epBB.x, epBB.y, epBB.z-lenBB)*mg, Vector(epBB.x, epBB.y, epBB.z+lenBB)*mg); } return SUPER::Draw(op, drawpass, bd, bh); }
On 11/07/2008 at 13:31, xxxxxxxx wrote:
Thanks for the code snippet, but I can't solve it... I will try it again, tomorrow..
On 11/07/2008 at 13:46, xxxxxxxx wrote:
i couldn't give up.. it works
kuroyume.. you are the best... bye
