On 30/06/2008 at 03:16, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5 Platform: Language(s) : C++ ;
--------- Hi!
I try to set the datatype "Filename" to a xpresso-node-outport, but GvPort has no such member.
Bool Calculate(GvNode *bn, GvPort *port, GvRun *run, GvCalc *calc) [...]
port->SetInteger.. <--works port->SetFilename <-- not avaible
What can I do?
Thanks and bye
On 30/06/2008 at 15:03, xxxxxxxx wrote:
port->SetString() ? Any particular reason why you couldn't use that?
On 30/06/2008 at 17:40, xxxxxxxx wrote:
Did you try port->SetData()? GeData has direct Filename access. Check the "Graph view data format" chapter of the docu for examples of port->SetData().
