On 25/06/2008 at 04:25, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.x Platform: Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- I overloaded the Timer class in my dialog to be triggered every 2000 ms. Is it possible to get a mouse or keyboard event from within the overloaded Timer class? I want to be able to read a key or a mouse down event. But it only seems to be possible inside a user area. Isn't it possible to read the keyboard or mouse from anywhere else?
Rui Batista
On 25/06/2008 at 23:46, xxxxxxxx wrote:
Anyone? Is it possible at all?
On 26/06/2008 at 02:29, xxxxxxxx wrote:
Unfortunatly there is no global GetInputState() function in COFFEE. So I don't think this is possible.
On 26/06/2008 at 06:39, xxxxxxxx wrote:
Mmmmm, thank you, Matthias. Do you know when will COFFEE get an update? Like adding a global GetInputState() function and being able to create Tracks and Keyframes?
On 26/06/2008 at 08:04, xxxxxxxx wrote:
Wasn't there an update called C++? (dives to ground, crawls to nearest cover, and waits for barrage).
On 26/06/2008 at 10:06, xxxxxxxx wrote:
C++ may be nice but not as fast for debugging. In COFFEE I type my code, run Cinema4D and test it really fast. With C++ I have to wait for compilation, linking, etc... Honestly, COFFEE suits much more my programming style (I'm not a true programmer).
On 28/06/2008 at 15:40, xxxxxxxx wrote:
Howdy,
Hehe, I think you should use whatever suits you.
But, it would be cool, though if there was a COFFEE API, so that you could use C++ to add custom functions to COFFEE. Then you could do a lot of those things in COFFEE that you can now only do in C++. One of the main reasons I moved to C++ was because of the limitations of COFFEE. ;o)
Adios, Cactus Dan
On 28/06/2008 at 16:37, xxxxxxxx wrote:
Actually you can extend COFFEE through the C++ COFFEE library. There is a chapter about it in the C++ docu.
On 28/06/2008 at 16:43, xxxxxxxx wrote:
Well, now that is cool!
I never noticed that library before.
