Increase speed of console
    On 13/06/2008 at 01:35, xxxxxxxx wrote:
    Cinema 4D Version:   10.5
    Platform:
    Heyho,
    I am in search of a possibility to print something to a seperate console.
    In my case a tag writes a String to a C4DGadget (MultiTextEdit).
    But its toooooo slow.
    output += newOutput;
    SetString(C4DGadget, output);
    Is it possible to print more than one line to the StaticText?
    String + GeGetLineEnd + String didn't work.
    Bye..
    On 24/06/2008 at 01:10, xxxxxxxx wrote:
    writing more lines should work with "textline1 /n textline2"
    On 24/06/2008 at 06:54, xxxxxxxx wrote:
    Hi!
    I have no problems with multilines. I tried String + \n + String. Cinema 4D slows down, because it refreshs the Multitextbox each frame. ( because it is a console)
    per frame / one new textline.
    But refreshing the textbox each frame slows c4d down. That's the point. Why?
    On 24/06/2008 at 07:02, xxxxxxxx wrote:
    Then why not using a static text field?
    On 24/06/2008 at 07:20, xxxxxxxx wrote:
    Does the static text support multilines?
    String + GeGetLineEnd() + String doesn't work.
