DTYPE_LONG description element
On 31/05/2008 at 06:39, xxxxxxxx wrote:
Cinema 4D Version:   10.5
Platform:   Windows  ;
Hi, this is some really weird stuff. I've got some DTYPE_LONG-custom description elements which are added in GetDDescription like here:
> <code>
> Bool MoCap::GetDDescription(GeListNode* node, Description* description, LONG& flags){
>      //load the available resource file
>      if (!description->LoadDescription(node->GetType())) return FALSE;
>      BaseContainer count = GetCustomDataTypeDefault(DTYPE_LONG);
>      count.SetString(DESC_NAME, "Count");
>      if (!description->SetParameter(DescLevel(DESC_CHILDREN, DTYPE_LONG, 0), count, DescLevel(MAIN_GROUP))) return TRUE;
>      flags |= DESCFLAGS_DESC_LOADED;
>      return TRUE;
> </code>
Strangely you can change the long value dragging the mouse without any problem. But when you manually put in the value and press the return button, a memory error occurs. This doesn't happen when you e.g. press the tab button instead of return. Any ideas?
J.
On 02/06/2008 at 06:15, xxxxxxxx wrote:
Problem solved...
