On 27/05/2008 at 17:23, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5 Platform: Language(s) : C++ ;
--------- Hi
I have a question. I create a textfile with a texteditor and import it via the BaseFile function. The same on Win doesn't work and I get crypted chars.
\> //Reads a file and returns a string \> //*---------------------------------------------------------------------------* \> String GetFileContent(Filename fn) \> //*---------------------------------------------------------------------------* \> { \> String line = String(""); \> \> AutoAlloc<BaseFile> bFile; \> bFile->Open(fn, GE_READ, FILE_IGNOREOPEN, GE_MOTOROLA, MACTYPE_CINEMA, MACCREATOR_CINEMA); \> \> String token, singleChar; \> LONG fileLength = bFile->GetLength(); \> \> CHAR c; \> CHAR* pc = &c; \> \> for (LONG i = 0; i != fileLength; i++) \> { \> bFile->ReadChar(pc); \> singleChar = pc; \> \> if (pc == "\n"){ \> line += "\n"; \> } \> else { \> line += pc; \> } \> } \> bFile->Close(); \> \> return line; \> }` Could someone give me a tip how to do it on win too? Thanks and bye :)
On 27/05/2008 at 21:05, xxxxxxxx wrote:
Unfortunately, "\n" on PC is TWO bytes (CHARs) - 0x0D+0x0A. You'll have to check for both of these as line endings:
// - PC uses CR+LF (0x000D+0x000A), Mac uses CR (0x000D) if ((c == 0x0D) || (c == 0x0A)) ...
On 28/05/2008 at 09:22, xxxxxxxx wrote:
Hi!
Thank you... I don't know why, it doesn't work. I only get crypted chars. For example "Hello" in a normal textfile is converted to
åƒ'ªƒƒ∂ª'å∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂∂
Do you know, what I do wrong?
Thanks
On 28/05/2008 at 12:04, xxxxxxxx wrote:
works!! thanks to kuroyume0161
