What Kind of Tiff for the Icon's Menu?
On 27/05/2008 at 08:22, xxxxxxxx wrote:
Cinema 4D Version: R10.5
Platform: Windows ;
Language(s) : C.O.F.F.E.E ;---------
Hi.
I can not put an icon to my PlugIn. My source code is:PlugInMenu::GetIcon()
var fn = GeGetRootFilename();
fn->RemoveLast();
fn->AddLast("icon.tif");
var bm = new(BaseBitmap, 1, 1);
bm->Load(fn);
return bm;
}And even that I work well with other icons (tiff) of other PlugIns, with the icon that I made (Photoshop) not work ... Why?
Thanks
Please, sorry for my very bad English... :-(
On 27/05/2008 at 12:20, xxxxxxxx wrote:
Hi!
You want to add an icon to the entry of your Plugin in the PluginMenü? Look at the position of the plugin-registry.
//Hook to register Plugin
Bool RegisterEditorEntry(void)
return RegisterCommandPlugin(YOUR_ID,String("I am a CommandPlugin"),false,ICON,String("opens the CommandPlugin"), gNew TheCommandClass);
}Hi, look at ICON. Replace it with a function, to get youricon.
> <code>
> static BaseBitmap* GetMyGroupIcon()
> //Naturally you can replace the following part with something
> like icon->Init(Filename...) Look after the BaseBitmap Class in the doc
> static AutoAlloc<BaseBitmap> icon;
> if (!icon) return NULL;
> if (icon->GetBw() == 0)
> icon->Init(24, 24);
> icon->Clear(200, 0, 0);
> return icon;
> </code>
On 27/05/2008 at 15:03, xxxxxxxx wrote:
He's using COFFEE, not C++ (I've done this myself about a million times). :)
Examine this code to see how it should be done:
// Included symbols
include "c4d_symbols.h"// Global references
var resource;
var plugin_path;
var plugin_icon;
var d;// CLASS: Drop Object Menu - Register plugin in menu
class DropObject_MenuPlugin : MenuPlugin
public:
DropObject_MenuPlugin();
GetID();
GetIcon();
GetName();
GetHelp();
Execute(doc);
RestoreLayout(secret);
DropObject_MenuPlugin::DropObject_MenuPlugin() { super(); }
DropObject_MenuPlugin::GetID() { return PLUGIN_MENU_ID; }
DropObject_MenuPlugin::GetIcon() { return plugin_icon; }
DropObject_MenuPlugin::GetName() { return resource->GetString(PLUGIN_MENU_TEXT); }
DropObject_MenuPlugin::GetHelp() { return resource->GetString(PLUGIN_MENU_HELP_TEXT); }
DropObject_MenuPlugin::Execute(doc)
// Perform operation
d->Open(TRUE,-1,-1);
DropObject_MenuPlugin::RestoreLayout(secret)
// Called by C4D to restore the dialog
if (!d) d = new(FloorDialog);
d->RestoreLayout(secret);
}// Start of plugin
// Load Resource
if (!(plugin_path = GeGetRootFilename())) println("Unable to find plugin!");
plugin_path->RemoveLast();
if (!(resource = new(GeResource, plugin_path))) println("Unable to load resource!");// Load Icons
var icon_file = plugin_path->GetClone();
icon_file->AddLast("pluginicon.tif");
plugin_icon = new(BaseBitmap,1,1);
plugin_icon->Load(icon_file);// Register Plugins
Register(DropObject_MenuPlugin);// Create non-modal dialog
