On 11/05/2008 at 11:44, xxxxxxxx wrote:
Hi, I know that this is not the best place to ask this but i want to render a animation with net render and reading the Manual for NET Render i found this : If a scene needs a special plugin or module you have to install this plugin or module manually on all clients. the problem is that in the net render client window appears a error regarding the "Spots" plug in that i dont know of and i do not use this thing ... i installed all the modules that i use and plugin on the clients and the error still persist... i seek guidance from one who knows much more than i do ... pls help
On 11/05/2008 at 14:13, xxxxxxxx wrote:
Without the scene it is a bit difficult to help you. You can send the scene and a description of your problem to [email protected]. All support requests will be treated confidential.
On 11/05/2008 at 14:15, xxxxxxxx wrote:
uhhh ... and how do i send the file because it has 500mega ...anyway thankyou very much for youre help and understanding
