Crash when closing Cinema
On 02/05/2008 at 02:58, xxxxxxxx wrote:
Cinema 4D Version:   10.5
Platform:   Windows  ;
Hi, I've got a problem when closing Cinema. My tag plugin has to write some data when it is shut down. The folowing method is called inside the free()-method:
> \> \> void MoCap::SetBackIDs (){ \> \>      BaseDocument \*doc = GetActiveDocument(); \>      GePrint ("doc"); \>      if (!doc->GetFirstObject()){ \>           GePrint ("if"); \>           return; \>      } \>      BaseObject \*op = doc->GetFirstObject(); \>      GePrint ("op"); \>      BaseObject \*current; \>      GePrint ("current"); \>      BaseContainer \*opContainer = op->GetDataInstance(); \>      GePrint ("opContainer"); \>       \>      GePrint("MoCap::Free"); \> \>      while (op!= NULL){ \>           GePrint ("while"); \>      opContainer = op->GetDataInstance(); \>      opContainer->SetBool (DESC_USED, FALSE); \>      opContainer->SetLong (DESC_JOINT_ID, 0); \>      current = op->GetDown(); \>      if (current == NULL) \>           current = op->GetNext(); \>      if (current == NULL) \>           current = op->GetUp()->GetNext(); \>      op = current; \>      } \> \>      GePrint ("End Free()"); \> } \> \>
This works fine. The problem is, when closing Cinema the document already seems empty when calling this free-method. The console prints out "doc", but doesn't get any further. Does someone have an idea?
Thanks
On 02/05/2008 at 03:43, xxxxxxxx wrote:
You shouldn't use GetActiveDocument() within a tag. You should use the document the node (tag) is attached to.
node->GetDocument()
The node is passed to the classes' methods
Free(GeListNode *node)
cheers,
Matthias
On 02/05/2008 at 04:10, xxxxxxxx wrote:
Thx very much
On 02/05/2008 at 12:40, xxxxxxxx wrote:
...you should also be testing your variables before accessing them...
    BaseDocument *doc = GetActiveDocument();
     **if( doc )**
      BaseObject *op = doc->GetFirstObject();
      **if( op )
        BaseContainer *opContainer = op->GetDataInstance();
        **if( opContainer )
            ...yadda..
...or similar, etc.
