On 02/04/2008 at 02:17, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5 Platform: Mac OSX ; Language(s) : C++ ;
--------- Hi.
I have a small question again.:)
I have developed a few nodes, but one of the last ones makes me crazy. I developed the first Initator, so without a return value to an outport.
A calculator-node has a method called Calculate(...) which is called when a the frame changed or a calculation has been requested.
But how in initiators? I tried to search in the SDK Documentation, but there is only the reference to the CalculationTable. Is this the right way I have to look for? Hoped that there is a method instead of Calculation(...) which is requested (even when no outport is connected / avaible)
Thanks a lot
On 07/04/2008 at 08:39, xxxxxxxx wrote:
someone has a tip?
On 07/04/2008 at 09:19, xxxxxxxx wrote:
I will try to post an example. Btw. what kind of initiator are you interested in?
On 07/04/2008 at 09:37, xxxxxxxx wrote:
Hi!
Thanks.. Well, I have a node, which executes some commands, but they will not be executed in the Calculate(...) method when no outport is connected. But my node has no output ports..
On 19/04/2008 at 10:41, xxxxxxxx wrote:
HI!
Wanted to ask If somebody knows some info.
When I use a calculation-node and puts another node to the output-port the function/method "calculate" is called and I can calculate the part I want.
But which function/method is called when my node has no outport?
Thanks
