Real from inport to outport
On 24/03/2008 at 09:41, xxxxxxxx wrote:
Cinema 4D Version:   10.5
Platform:      Mac OSX  ;
Hi!
I have a big problem with the SDK and the documentation to get the following case. I want to create one inport / one outport (Datatype: Real).
The outport should only forward a number of the inport.
I created 3 functions / classes.
\>  GeData GvGetPortGeData(GvNode* node, GvPort* port, GvRun* run)
\>  //and so on...//
\>  Bool GvSetPortGeData(const GeData& ge_data, GvNode* node, GvPort* port, GvRun* run)
\>  //and so on...//
\>  class GVIteratorTest : public GvOperatorData
\>  //and so on...//
\>  Bool Calculate(GvNode *bn, GvPort *port, GvRun *run, GvCalc *calc)
\>  GvSetPortGeData(GeData(3000),bn, port, run);
\>      return FALSE;
\>  //..blabla//
Alright. It works. With the line GvSetPortGeData(... I am able to set the Real 3000 from the outport. But how do I get the Real from the inport called inport_LINK.
Thank you very much.
On 25/03/2008 at 10:39, xxxxxxxx wrote:
Hi!
Okay, perhaps I simplify my problem.
\>            GvValue* vinport = ports.in_values[inport_LINK];
\>            GvPort* inport = vinport->GetPort();
\>            GeData inportdata = GvGetPortGeData(bn, inport, run);
\>            Real normale = inportdata.GetReal();
\>            GePrint(RealToString(normale));
This code I paste before I return the value to "set" the outport data. But in the Console (see GePrint) the value is 0. The inportvalue with a constant is 25. I only have 1 inport.
Whats my mistake?
Thank you very much 🙂
On 26/03/2008 at 08:49, xxxxxxxx wrote:
Sorry for asking again, but did nobody got a node to work, that imports a normal Real number?
Thanks a lot
On 26/03/2008 at 09:06, xxxxxxxx wrote:
I will look into it.
cheers,
Matthias
On 27/03/2008 at 06:56, xxxxxxxx wrote:
Thanks a lot 🙂
On 28/03/2008 at 07:37, xxxxxxxx wrote:
Ok, here is my Calculate function of the node. It outputs the input.
> \> static LONG input_ids[] = { GV_REAL_INPORT, 0 }; // Use this for the input ports! \> \> Bool MyNode::InitCalculation(GvNode \*bn, GvCalc \*calc, GvRun \*run) \> { \>      return GvBuildInValuesTable(bn, ports, calc, run, input_ids); \> } \> \> void MyNode::FreeCalculation(GvNode \*bn, GvCalc \*calc) \> { \>      GvFreeValuesTable(bn, ports); \> } \> \> Bool MyNode::Calculate(GvNode \*bn, GvPort \*port, GvRun \*run, GvCalc \*calc) \> { \>      if(!port) return FALSE; \> \>      GvValue \*vinport = ports.in_values[0]; \>      if(!vinport) return FALSE; \> \>      if(!vinport->Calculate(bn, GV_PORT_INPUT, run, calc, 0)) return FALSE; \> \>      GvPort \*inport = vinport->GetPort(); \> \>      Real value = 0.0; \> \>      inport->GetReal(&value;,run); \> \>      GePrint(RealToString(value)); \> \>      switch(port->GetMainID()) \>      { \>           case GV_REAL_OUTPORT: \>           { \>                return port->SetReal(value,run); \>           } \>      } \>       \>      return FALSE; \> } \>
GV_REAL_INPORT and GV_REAL_OUTPORT are from my ressource file
> \> CONTAINER GVmynode \> { \>      NAME          GVmynode; \>      INCLUDE GVbase; \> \>      GROUP          ID_GVPORTS \>      { \>           REAL     GV_REAL_INPORT \>           { \>                INPORT; \>                STATICPORT; \>                CREATEPORT; \>           } \>           REAL     GV_REAL_OUTPORT \>           { \>                OUTPORT; \>                STATICPORT; \>                CREATEPORT; \>           } \>      } \> } \>
cheers,
Matthias
On 28/03/2008 at 08:28, xxxxxxxx wrote:
Hi!
Amazing. Thanks for great Work. Now, i see my mistake.
May the force be with you 😘
On 28/03/2008 at 12:43, xxxxxxxx wrote:
Hi!
I have a short question again.
I tried to get several inports. I am confused a little bit. If I input some vectors via the attributemanager (about the port-inputs) the node add the two vectors.
But when I connect to vectors via two other nodes, the node adds ValueA with the vector (0;0;0)... Does someone find the mistake?
I am confused a lot. Thanks for help..
GvValue* vinport = ports.in_values[0];
     if (!vinport) return FALSE;
     if (!vinport->Calculate(bn, GV_PORT_INPUT_OR_GEDATA, run, calc, 0)) return FALSE;
        GvValue* vinportA = ports.in_values[1];
     if (!vinportA) return FALSE;
     if (!vinportA->Calculate(bn, GV_PORT_INPUT_OR_GEDATA, run, calc, 0)) return FALSE;
     GvPort* ipt = bn->GetInPort(0);
     GeData iptdata = GvGetPortGeData(bn, ipt, run);
     Vector valueA = iptdata.GetVector();
GvPort* iptA = bn->GetInPort(1);
     GeData iptdataA = GvGetPortGeData(bn, iptA, run);
     Vector valueB = iptdataA.GetVector();
     Vector valueC;
On 28/03/2008 at 17:02, xxxxxxxx wrote:
sry, problem solved...thanks
