On 15/03/2008 at 16:54, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9-R10.5 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- I've checked and my import to Spline object creates the correct number of points on the spline object. And "Object Properties" displays the correct number of points (in agreement). But if I print out obj->GetPointCount(), I get a different value (1196 instead of 1140, for instance).
What the ...? It is causing me grief as I am trying to animate the spline object from a file with 1140 (e.g.) points per frame. Is there a reason why the number of points differs from the number of points in the Vector* array?
Thanks,
On 15/03/2008 at 20:59, xxxxxxxx wrote:
Found the problem - counting one more than needed from the file by not advancing the character index in the line. Never showed up as a problem before because this only occurs during the prepass for counts (counts were always a bit bigger so doesn't affect much). Now they are accurate.
Back to work.
