CalcVolumetric
On 04/02/2008 at 04:32, xxxxxxxx wrote:
Cinema 4D Version: 9.6 10.5
Platform: Windows ;
Language(s) :---------
Hi,I need to get a depth map of my scene in CalcVolumetric on in another method during the rendering process. I know that Cinema can process this depth map but it doesn't help me since my plugin should then activate itself this multipass effect and I don't want that, and I want to use my parameters for my depth map.
I tried first with vd->dist but in the case of a texture using displacement or transparency the results are not good enough.
So I tried with TraceGeometry in CalcVolumetric with the following code:
SurfaceIntersection hit;if (vd->TraceGeometry(vd->ray,1000000.0,NOTOK,&hit;))
LVector vec(hit.p.x-drcCurrent.camMatrix.off.x,hit.p.y-drcCurrent.camMatrix.off.y,hit.p.z-drcCurrent.camMatrix.off.z);
dist = Len(vec);
else
dist = vd->dist;
}The results are a bit better but some pixels are not correct, see the image below:
The ring has the displacement texture. Something similar is coming with transparency.
I read that it cannot work because the ray casting is off or not working (I don't remember) with displacement.
Well, how should I get my depth map during the rendering ?
Thanks a lot in advance.
Vincent
