Assigning a material to a material tag
On 30/12/2007 at 15:54, xxxxxxxx wrote:
Cinema 4D Version: 10.5
Platform: Mac OSX ;
Language(s) : C.O.F.F.E.E ;---------
Hi,I want to create and assign a material in COFFEE, but this line generates an error:
> tag- >SetMaterial(material);
In the COFFEE doc, I found that the SetMaterial methods wants a MARKER. What is that and how can I transform a material into a marker?
This is my code for creating & assigning a material in COFFEE:
> _
> // getting the selected object
> if (!(obj = doc->GetActiveObject())) return;
> // creating a new material and a new texture tag
> if (!(material = AllocMaterial(Mmaterial))) { println("Error: AllocMaterial"); }
> if (!(tag = AllocTag(Ttexture))) { println("Error: AllocTag"); }
> // assigning the texture tag to the object
> if( !(obj->InsertTag(tag))) { println("Error: InsertTag"); }
> // insering the new material to the document
> if (!(doc->InsertMaterial(material, NULL))) { println("Error: InsertMaterial"); }
> // assigning the material to the texture tag
> tag->SetMaterial(material);
> // enabling the Color channel for the material
> material->SetChannelState(CHANNEL_COLOR, TRUE);
> // getting the path for the texture
> file = GeGetRootFilename();
> if (!file) return;
> file->RemoveLast();
> file->AddLast("tex.jpg");
> // assigning the texture to the Color channel
> if (!(channel = material->GetChannel(CHANNEL_COLOR))) { println("Error: GetChannel"); }
> if (!(container = channel->GetContainer())) { println("Error: GetContainer"); }
> container->SetData(CH_TEXTURE, file->GetFullString());
> channel->SetContainer(container);
> _Thanks for your help!!
On 31/12/2007 at 03:37, xxxxxxxx wrote:
This works for me:
> var mat = AllocMaterial(Mmaterial);
> doc- >InsertMaterial(mat, NULL);
> mat->SetName("Hello Material");
> var tag = AllocTag(Ttexture);
> op->InsertTag(tag);
> var bc = tag->GetContainer();
> bc->SetData(TEXTURETAG_MATERIAL , mat);
> tag->SetContainer(bc);
On 31/12/2007 at 05:29, xxxxxxxx wrote:
Ah, you extract the container from the tag, modify it and write it back. OK, I'll try it out.
Thanks
