Loading a Fresnel and Brickshader?
    On 26/12/2007 at 15:28, xxxxxxxx wrote:
    Cinema 4D Version:   10.5
    Platform:      Mac OSX  ;
    I know how to create and assign a new material to an object in COFFEE. I also know how ot enable different channels and how to play with their settings. Loading a texture also is possible.
    But how do you load 1) a Fresnel and 2) a Brickshader? Is it also possible to change the settings of the Brickshader in COFFEE?
    On 27/12/2007 at 13:38, xxxxxxxx wrote:
    No one? Is this not possible in COFFEE?
    On 28/12/2007 at 09:49, xxxxxxxx wrote:
    I am not sure if it´s possible to add a channel shader via COFFEE. You can define a texture like so in the BaseChannel (see docs for more info on BaseChannels) :
    var bump = doc->GetChannel(CHANNEL_BUMP);
    var bumpBc = bump->GetContainer();
    bumpBc->SetData(CH_TEXTURE, "foo.tif");
    bump->SetContainer(bumpBc);
    There is GetShaderContainer() and SetShaderContainer(). This should be the functions you need to use. Create a brick shader in c4d and read out the shader container to see how it is built up, then you may be able to recreate and set it customly.
