On 26/12/2007 at 15:11, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.111 Platform: Windows ; Language(s) : C++ ;
--------- Hi,
in my expression tag, I use an InExcludeList Element to get a list of objects from the user. But I have some problems...
In the Execute() function, I do the following:
1. Get the List of objects that are linked in the InExclude box:
> _ > GeData myList; > tag->GetParameter(DescID(SCOOBYCAMEXP_LIST), myList, NULL); > InExcludeData* SC_List = static_cast<InExcludeData*>(myList.GetCustomDataType(CUSTOMDATATYPE_INEXCLUDE_LIST)); > _
2. Get the number of linked objects:
> _ > LONG ListCount = SC_List->GetObjectCount(); > _
But the value that is returned, is not always correct. For example, I have linked 6 objects in the list, it returns 6. But when I delete some of those objects from the scene (without removing them from the InExclude box first) it still returns 6.
I only want my calculations to be performed if there are at least 2 objects linked in the list. But because of the problem described above, the following code does not work:
> _ > if (ListCount > 1) > { > GePrint("Hello World"); > } > _
It always prints "Hello World", even if there is only 1 or even 0 objects in the list.
What can I do? Is there some way to refresh the InExclude box? Do I have to free myList or SC_List at the end of the Execute() function? How would that work?
Best regards & big thanks for any help, Jack
On 26/12/2007 at 15:20, xxxxxxxx wrote:
Since InExcludeData accepts pointers deleting the actual object doesn't remove the pointer from the InExcludeData object.
Hope i'm not way off here, i didn't actually test this
On 26/12/2007 at 16:57, xxxxxxxx wrote:
So what's best to do?
Maybe iterating all items in the list, checking if there's a real object in it, and remove the item from the list if it's not?
There must be an easier way, I can't believe they let all developers write this function themselves. That would be nasty
Greetings, Jack
On 26/12/2007 at 17:15, xxxxxxxx wrote:
There's nothing mentioned on pointers being deleted if there is no object, so i wouldn't think there is any way around this except removing them manually. I don't think those few extra lines of code would hurt you too much though.
I hope someone with more experience with this will give you a better solution...
On 27/12/2007 at 03:23, xxxxxxxx wrote:
OK, now I get the ObjectCount from a separate function that first checks all object pointers in the list, and removes the invalid ones.
But that means, this function is called every frame. Is there any function I could use instead of the Execute() so my function is only called when the user really *does* something in the ObjectManager ?
On 27/12/2007 at 04:11, xxxxxxxx wrote:
I'd use
> virtual Bool Message(GeListNode* node, LONG type, void* data)
you have tons of types of messages, just check the sdk for the one that suites you best
On 28/12/2007 at 09:44, xxxxxxxx wrote:
Simply try direct container access. The list updates itself automatically:
(InExcludeData* )tag->GetDataInstance()->GetCustomDataType(SCOOBYCAMEXP_LIST, CUSTOMDATATYPE_INEXCLUDE_LIST);
