GeDynamicArray access violation
    On 17/12/2007 at 01:24, xxxxxxxx wrote:
    Cinema 4D Version:   9.5+
    Language(s) :
    Greetings,
    I have a rather strange problem. I'm using GeDynamicArray (GeDynamicArray<Real> data;) in some class (layer_graph_data), and it seems to crash when c4d wants to free it. The funny thing is, it crashes only when using layer_graph_data as a pointer, eg. layer_graph_data* a=new layer_graph_data(); delete(a); and only if it's created in another class (layer_data in my example, which is allocated in the main ObjectData class), but works quite fine when allocated in the main class. And it works just fine with layer_graph_data a; in either of those two examples.
    Debugger says the exception happens in
    GeFree(ptr); of template<class TYPE> void GeDynamicArray<TYPE>::Free(void) in ge_dynamicarray.h.
    Any ideas why this might happen?
    Thanks,
    Miha
    On 17/12/2007 at 01:52, xxxxxxxx wrote:
    No clear idea what might cause the crash without seeing your source code. Just remember to use Cinema's own allocation functions (bNew, bDelete, gNew, gDelete etc.) whenever possible.
    cheers,
    Matthias
    On 17/12/2007 at 02:21, xxxxxxxx wrote:
    _
    > #pragma once
    > #include "c4d.h"
    > #include "ge_dynamicarray.h"
    > class layer_graph_data {
    > private:
    >      LONG size;
    >      LONG channel;
    >      LONG delay;
    > public:
    >      layer_graph_data(void);
    >      layer_graph_data(LONG _channel);
    >      ~layer_graph_data(void);
    > layer_graph_data::layer_graph_data(void) {
    >      size=0;
    >      delay=0;
    >      channel=0;
    > layer_graph_data::layer_graph_data(LONG _channel) {
    >      size=0;
    >      channel=_channel;
    >      delay=0;
    > layer_graph_data::~layer_graph_data(void) {
    > #include "c4d.h"
    > #include "layer_graph_data.h"
    > class layer_data
    > private:
    >      Real max;
    >      String name;
    >      LONG channel;
    >      Vector namebox;
    >      Real exp;
    >      layer_graph_data* graph_data;
    > public:
    >      Vector corner_LT, corner_RB, off1, off2;
    >      Bool selected;
    > public:
    > public:
    >      layer_data(void);
    >      layer_data(Vector _corner_LT, Vector _corner_RB);
    >      ~layer_data(void);
    > #include "Layer.h"
    > layer_data::layer_data(void)
    >      graph_data=gNew layer_graph_data();
    >      graph_data->setChannel(channel);
    >      exp=2;
    > layer_data::~layer_data(void)
    >      gDelete(graph_data);
    > layer_data::layer_data(Vector _corner_LT, Vector _corner_RB)
    >      corner_LT = _corner_LT;
    >      corner_RB = _corner_RB;
    >      exp=2;
    > _
    in the main plugin class layer_data is used
    > _
    > private:
    > GeDynamicArray <layer_data> layer_store;
    > Bool Init(GeListNode *node) {
    > layer_store.Push(layer_data(Vector(0.1,0.1,0),Vector(0.2,0.3,0)));
    >      layer_store.Push(layer_data(Vector(0.3,0.4,0),Vector(0.4,0.6,0)));
    >      layer_store.Push(layer_data(Vector(0.2,0.2,0),Vector(0.3,0.8,0)));
    > _
    hope this makes sense. :)
    On 17/12/2007 at 02:37, xxxxxxxx wrote:
    Ok now that is weird. When i changed GeDynamicArray_<_layer_data_>_ layer_store; to GeDynamicA_<_layer_data*_>_ta*> layer_store; and used gNew and gDelete on its elements it resolved itself...
    On 17/12/2007 at 05:50, xxxxxxxx wrote:
    I also encountered crashes with GeDynamicArray some time ago, however only in a multiprocessor context and when trying to change the stacked array during MP processing (for example during rendering).
