On 03/12/2007 at 22:32, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.1.1 Platform: Mac ; Language(s) : C.O.F.F.E.E ;
--------- Greetings, I've had some luck, with kuroyume0161's help, creating a speedy file parser. I'd like to take this to the next level- to allow a user to simply type in one or more of the 47,509 unique 4 digit codes that will allow them to access the file for the available molecule. The code itself seems trivial, e.g. if the file were on a local drive, one could use FileManipulation and BaseFile elements to access, but I can't find a function that will grant me access to the web....I simply want to access information in an ASCII file, either download it, or not, at a URL with a variable 4 digit code on its tail, .../xyzn.pdb, for example, http://www.rcsb.org/pdb/files/2onj.pdb. Does such a function exist in coffee? If not, how about in the C++ SDK? If not there, has anyone had luck firing up such a script in another language and using Coffee to run it? I'd be happy to launch some other app behind the scenes that can do this and download the files I need into a folder that the rest of the Coffee script would allow me to manipulate them, but I really want an end user to be able to do this, without worry, directly from a simple C4D dialog. Might the [type] and [creator] elements of Open under BaseFile in the SDK allow such an option? If so, how could I find out what integer to use for a creator other than C4D, like, I don't know, Apple's "Automator"? Thanks, Graham
On 04/12/2007 at 13:00, xxxxxxxx wrote:
Hi, Does anybody have any input on this topic? Can you script Coffee to download files from the internet? If not, can you tell it to open an external script, i.e. Automator that will open a default browser and download the needed files to a folder? Thanks, Graham
