On 11/11/2007 at 22:57, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.1 Platform: Windows ; Language(s) : C++ ;
--------- Hi,
I want to implement auto-banking for objects that are aligned to a spline.
I tried the method I found on base80.com: Calculating the banking angle from the difference of current and last Rot.H value. But this causes problems when the value 'increases' from 359° to 0°. It would be better to determine the 'curve angle' of the spline for a point on the spline. But how can do this?
Thanks for any tips & help!
Greetings, Jack
On 13/11/2007 at 02:42, xxxxxxxx wrote:
Nobody? No idea?
On 13/11/2007 at 03:15, xxxxxxxx wrote:
Hi Jack. AFAIK a "curve angle" from a point would be it's tangent but that would not be so reliable as a solid source. As for the flipping of a full turn (359->0 and 0->359) you can calculate the resulting minimum angle and use that Fortunately there is a function for it in the SDK. Look up "MinimizeAngle(a,b)" and you should be fine.
Cheers Lennart
On 13/11/2007 at 03:37, xxxxxxxx wrote:
MinimizeAngle?? Wow, the SDK surprises me every day again Thanks a lot, Lennart!
On 17/11/2007 at 05:08, xxxxxxxx wrote:
Well, unfortunately, there is no MinimizeAngle() function in the C++ SDK. But thanks anyway.
[EDIT]Ah, I see in C++ SDK it is called Vector GetOptimalAngle(const Vector& hpb_old, const Vector& hpb_new). Maybe I can make something out of that.[/EDIT]
On 17/11/2007 at 11:59, xxxxxxxx wrote:
GetOptimalAngle(), yes.
On 18/11/2007 at 06:04, xxxxxxxx wrote:
Hm, somehow it twists up all my angles. Now I wrote my own function and everything works fine. Thank you guys!
