Change Font
On 11/11/2007 at 05:58, xxxxxxxx wrote:
Cinema 4D Version: 10
Platform: Mac OSX ;
Language(s) : C.O.F.F.E.E ;---------
Hello everybody,
does anybody has an idea how to change the actual font with COFFEE?Drag and Drop into the console outputs me this command:
#PRIM_TEXT_FONT
Now the problem is i simply do not understand what kind of information i have to add now... everything i tried is not working... two values needed here? (postscript/true type + name of font?) maybe one of you knows, thanks in advance + greets
On 11/11/2007 at 07:12, xxxxxxxx wrote:
Hi Cheetah,
as far as I know you can not access the font type through coffee.
On 11/11/2007 at 08:28, xxxxxxxx wrote:
...thanks for your answer FrankBerg. Are you sure about that? I ask myself why its then possible to get its name (#PRIM_TEXT_FONT) by dragging and dropping it into the console window... there has to be a way (yes i have still hope) any other experience anybody?
On 11/11/2007 at 18:31, xxxxxxxx wrote:
I read it is not even possible through the C++ SDK, there you can only get the font and set its type to another text spline..not choose a different font. And every attribute has a ID.. doesn't mean you have access to it.
On 12/11/2007 at 08:41, xxxxxxxx wrote:
okay, thanks for searching... too bad, type designers would love it :)
