On 05/11/2007 at 05:18, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.x Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- I am trying unsuccessfully to have COFFEE undo the creation of a base tag in R10.x.
Undo calls work perfectly in the following example in R9.6 but have no effect in R10.x. (This code goes into a COFFEE expression tag with a Boole user data element to trigger creation of a display tag.)
> _ > main(doc, op) > { > var ttag = op- >GetFirstTag(); > > while(ttag->GetType() != Tcoffeeexpression) > { > ttag = ttag->GetNext(); > } > > var addTag = ttag#ID_USERDATA:1; > > doc->StartUndo(); > > if(addTag) > { > var dispTag = AllocTag(Tdisplay); > op->InsertTag(dispTag); > doc->AddUndo(UNDO_NEW, dispTag); > } > > ttag#ID_USERDATA:1 = FALSE; > doc->EndUndo(); > } > _
Can anyone tell me why this is not working in R10.x?
On 05/11/2007 at 05:36, xxxxxxxx wrote:
To be honest this loks like a hack. You shouldn't create nodes (object/tags/materials, etc.) from within an expression. An expression plugin with an interface where you can catch a button message is probably a better idea because this happens outside of the expression.
On 05/11/2007 at 15:30, xxxxxxxx wrote:
Thanks for the guidance, Matthias. Looks like I'll have to create an interface for the plugin. Björn mentioned this on the CGTalk forum a couple of years ago too but I had forgotten.
