On 27/10/2007 at 17:33, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.111 Platform: Language(s) : C++ ;
--------- How would I add an item to the Multi-Pass list (for example, the Reflection channel) in the Render Settings?
On 29/10/2007 at 08:14, xxxxxxxx wrote:
Here is a function that I wrote to insert a multipass channel into the render settings:
BaseContainer* HybridMPChannel(LONG multipassChannel) { RenderData *renderData = GetActiveDocument()->GetActiveRenderData(); if(!renderData) return NULL; BaseContainer *rdata = renderData->GetDataInstance(); if(!rdata) return NULL; BaseContainer bc; BaseContainer *multipassData = rdata->GetContainerInstance(RDATA_MULTIPASS_CHANNELS); if(!multipassData) { GeData *mChannels = rdata->InsData(RDATA_MULTIPASS_CHANNELS, GeData(bc)); multipassData = mChannels->GetContainer(); if(!multipassData) return NULL; } GeData* d = multipassData->InsData(multipassChannel,GeData(bc)); BaseContainer *channelData = d->GetContainer(); return channelData; } BaseContainer *buffer = HybridMPChannel(VPBUFFER_REFLECTION); buffer->SetBool(RDATA_MULTIPASS_ACTIVE, TRUE);
You can find all of the defined LONG's for the different mp channels in the RenderData class of the SDK. Josh
On 30/10/2007 at 00:00, xxxxxxxx wrote:
Thank you!
That's very helpful.
