On 06/10/2007 at 17:29, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6-10.5 Platform: Windows ; Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- Hi. Stuck on basics again I'm afraid. On my Tags I have Linkfields (UserData) I drag objects into them and use those objects for further calculations.
Problem is to truly clear the links if for example; -1 The objects is deleted from the scene (in OM) or, -2 The object is of wrong type (that I have descided.
What happends is the object is still "virtually" there. The linkfield is only truly cleared if there is an object there and I use the small DropDown menu on the right side and pick "Clear".
Is it possible/how do I get that dropdown menu? I've searched here and found some threads, but they are C++ and I can't really interpret that to coffee.
I assume I have to get the Tags BaseContainer and get the Linkfield ID (and not the object_ID in the linkfield) And there is where I'm stuck...
Cheers Lennart
On 07/10/2007 at 01:23, xxxxxxxx wrote:
You cannot access Linkfields in COFFEE. The only way I see is to use tagBaseContainer->SetData(LINKFIELD_ID, NULL);
