Load/Save Presets?
On 15/09/2007 at 09:06, xxxxxxxx wrote:
Cinema 4D Version: 10.111
Platform: Windows ;
Hi,I want a function to load and save the data of all parameters of my expression tag. All Sliders and Spline Curves and so on.
Is there a way for storing all the parameters I want to be saved in a NodeData() object and save it to / load it from a file?
Thanks for help.
Greetings,
Jack
On 15/09/2007 at 12:42, xxxxxxxx wrote:
Anything defined in the resource as descriptions for the plugin tag is loaded/saved automatically. You do not EVER need to load and save these yourself - probably not recommended either.
Anything not defined there, such as class variables, should be loaded/saved using Read()/Write()/CopyTo() (when you use one of these methods, all three must be defined in the plugin Data - your TagData derived class).
If any variables depend on other tags/objects/etc., you'll want to set them by checking for the MSG_MULTI_DOCUMENTIMPORTED message in Message() for your tag. This guarantees that the entire document has been loaded for proper referencing.
On 15/09/2007 at 15:00, xxxxxxxx wrote:
I know that all settings are stored in the scene. But I want to be able to store his settings to a file, so he can archive his favourite settings. Like presets.
Greetings,
Jack
On 15/09/2007 at 15:39, xxxxxxxx wrote:
Oh, that's more explanatory! :)
For something like presets, you'll have to devise a file format and use a BaseFile and its methods or write a text file (fprintf/fscanf?). Possibly a hard-named file (I use, for instance, ipptool.prf for my tool settings) or you can open a file dialog so that the user can load from/save into a particular file.
How to read/write the presets depends upon which way you go: BaseFile or C/C++ methods. For the C4D types, you'll need to convert for the latter method (write 1/0 or TRUE/FALSE for bools and so on). If you need some example code, I can provide it but you should be able to get the hang of it. Try a single variable first for read and write to test the veracity. Once that is established, fill out all of the reading/writing to be done.
On 15/09/2007 at 17:45, xxxxxxxx wrote:
yeah, some example code would be great!
I had hoped for some possibility to write the complete contents of a PluginData or BaseContainer class into a file. That way, I would just have to copy the settings that should be saved to a separate BaseContainer and write a kinda BaseContainer File.
Regards,
Jack
On 15/09/2007 at 18:26, xxxxxxxx wrote:
Unfortunately, there is no WriteContainer/ReadContainer. ;)
These methods do exist in the HyperFile but have not tried this approach. This may suffice for your requirements.
Otherwise, this is my entire plugin preferences load and save methods; a bit much, but it show everything needed. Note that the BaseFile* is passed in from the dialog so you'll want to either do similar or AutoAlloc the BaseFile and Filename::Select to get the file to open for read/write. Also note that this file tracks the version so as to ignore newer settings.
// CMD: Load Settings from Prefs file //*---------------------------------------------------------------------------* BOOL Settings::LoadSettings(BaseFile* baseFile, BOOL loadDefault) //*---------------------------------------------------------------------------* { // Load either Default or User-Selected Preferences Filename baseFilename; if (!loadDefault) { baseFilename = GeGetPluginPath(); if (!baseFilename.FileSelect(0, 0, &GeLoadString;(IPPS_LOADPREFS_DLG))) return TRUE; } else baseFilename = prefs_Filename; baseFile->Close(); // Open file if (!baseFile->Open(baseFilename, GE_READ, FILE_NODIALOG)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_OPENFILE_TEXT), baseFilename.GetString()); Filename ppath; LONG longv; UCHAR version[3]; // Read interPoser Pro Preferences Version baseFile->ReadBytes(&version;[0], 3); // v0.4.3 // General // - Read BOOL autoPrefs if (!baseFile->ReadBool(&autoPrefs;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real objScaling if (!baseFile->ReadReal(&objScaling;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read Real infiniteLightRadius if (!baseFile->ReadReal(&infiniteLightRadius;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Scene // - Read BOOL includeCameras if (!baseFile->ReadBool(&includeCameras;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL includeLights if (!baseFile->ReadBool(&includeLights;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL includeGround if (!baseFile->ReadBool(&includeGround;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Dials // - Read BOOL overrideMorphEdit if (!baseFile->ReadBool(&overrideMorphEdit;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real morphEditMin if (!baseFile->ReadReal(&morphEditMin;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real morphEditMax if (!baseFile->ReadReal(&morphEditMax;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real morphEditStep if (!baseFile->ReadReal(&morphEditStep;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Materials // - Read BOOL useTMin if (!baseFile->ReadBool(&useTMin;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL useReflection if (!baseFile->ReadBool(&useReflection;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL useSpecularMode if (!baseFile->ReadBool(&useSpecularMode;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL useIllumModel if (!baseFile->ReadBool(&useIllumModel;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read LONG specularMode if (!baseFile->ReadLong(&specularMode;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read LONG illumModel if (!baseFile->ReadLong(&illumModel;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read ChannelSampling Sampling[6] for (INT i = 0; i < 6; ++i) { if (!baseFile->ReadBool(&(Sampling _.use))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadLong(&(Sampling _.sampling))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadReal(&(Sampling _.blurOffset))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadReal(&(Sampling _.blurScale))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } // Read BOOL useDisplacement if (!baseFile->ReadBool(&useDisplacement;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL heightAbsolute if (!baseFile->ReadBool(&heightAbsolute;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read LONG displacementType if (!baseFile->ReadLong((LONG* )&displacementType;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read LONG subdivisionLevel if (!baseFile->ReadLong((LONG* )&subdivisionLevel;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL roundGeometry if (!baseFile->ReadBool(&roundGeometry;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL roundContour if (!baseFile->ReadBool(&roundContour;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL mapRoundedGeometry if (!baseFile->ReadBool(&mapRoundedGeometry;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL mapResultingGeometry if (!baseFile->ReadBool(&mapResultingGeometry;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL keepOriginalEdges if (!baseFile->ReadBool(&keepOriginalEdges;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL bestDistribution if (!baseFile->ReadBool(&bestDistribution;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Filename Project path and verify if (!baseFile->ReadFilename(&ppath;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // v1.1.5: Consider migration from R9.6/PPC to R10UB #ifdef C4D_R10UB if (GeFExist(ppath, FALSE) || GeFExist(ppath, TRUE)) ProjectPath = ppath; // Check for no '/' path separators else if (!ppath.GetString().FindFirst('/', &longv;)) { String p = ppath.GetString(); // MacOS C4D R10 - change ':' to '/' while (p.FindFirst(':', &longv;)) p[longv] = '/'; if (p[0] == '/') ppath = Filename(String("/Volumes")+p); else ppath = Filename(String("/Volumes/")+p); if (GeFExist(ppath, FALSE) || GeFExist(ppath, TRUE)) ProjectPath = ppath; //else MessageDialog("Project: "+ppath.GetString()+" was not found!"); } //else if (ppath.Content()) MessageDialog("Project: "+ppath.GetString()+" was not found!"); #else if (GeFExist(ppath, FALSE) || GeFExist(ppath, TRUE)) ProjectPath = ppath; //else if (ppath.Content()) MessageDialog("Project: "+ppath.GetString()+" was not found!"); #endif // RuntimeExplorer // - Read Normal/Selected Color values if (!baseFile->ReadVector(&colorsExplorer;[0])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadVector(&colorsExplorer;[1])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadVector(&colorsExplorer;[2])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadVector(&colorsExplorer;[3])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadVector(&colorsExplorer;[4])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadVector(&colorsExplorer;[5])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Get Runtimes // -- Read LONG number of Runtimes if (!baseFile->ReadLong(&longv;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (longv) { bDelete(firstIPPRuntime); firstIPPRuntime = bNew IPPRuntime[longv]; if (!firstIPPRuntime) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_MEMORY_TEXT), "Settings.LoadSettings.firstIPPRuntime"); lastIPPRuntime = firstIPPRuntime + longv; Bool boolean; // -- Read Filename Runtime paths from file for (IPPRuntime* rt = firstIPPRuntime; rt != lastIPPRuntime; ++rt) { if (!baseFile->ReadBool(&boolean;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadFilename(&ppath;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // v1.1.5: Consider migration from R9.6/PPC to R10UB #ifdef C4D_R10UB if (GeFExist(ppath, TRUE)) { rt->enable = boolean; rt->path = ppath; GePrint("Runtime: "+ppath.GetString()+" Exists"); } // Check for no '/' path separators else if (!ppath.GetString().FindFirst('/', &longv;)) { String p = ppath.GetString(); // MacOS C4D R10 - change ':' to '/' while (p.FindFirst(':', &longv;)) p[longv] = '/'; if (p[0] == '/') ppath = Filename(String("/Volumes")+p); else ppath = Filename(String("/Volumes/")+p); if (GeFExist(ppath, TRUE)) { rt->enable = boolean; rt->path = ppath; } else MessageDialog("Runtime: "+ppath.GetString()+" not added!"); } else MessageDialog("Runtime: "+ppath.GetString()+" not added!"); #else // Verify existence if (GeFExist(ppath, TRUE)) { rt->enable = boolean; rt->path = ppath; } else MessageDialog("Runtime: "+ppath.GetString()+" not added!"); #endif } } // - Read String lastRTEFolder if (!baseFile->ReadString(&lastRTI;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (CheckInterPoserVersion(&version;[0], 0, 4, 7) >= 0) { // Read BOOL imageSearch if (!baseFile->ReadBool(&imageSearch;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL useMasterSlaves if (!baseFile->ReadBool(&useMasterSlaves;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 4, 8) >= 0) { // Read BOOL clearSelection if (!baseFile->ReadBool(&clearSelection;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Read BOOL storeUndoLoad if (!baseFile->ReadBool(&storeUndoLoad;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 4, 9) >= 0) { // Dials // - Read BOOL overrideParmEdit if (!baseFile->ReadBool(&overrideParmEdit;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real parmEditMin if (!baseFile->ReadReal(&parmEditMin;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real parmEditMax if (!baseFile->ReadReal(&parmEditMax;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real parmEditStep if (!baseFile->ReadReal(&parmEditStep;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 5, 8) >= 0) { // - Read BOOL logging if (!baseFile->ReadBool(&logging;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 6, 2) >= 0) { // Dials // - Read BOOL overrideTransEdit if (!baseFile->ReadBool(&overrideTransEdit;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real transEditMin if (!baseFile->ReadReal(&transEditMin;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real transEditMax if (!baseFile->ReadReal(&transEditMax;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real transEditStep if (!baseFile->ReadReal(&transEditStep;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 6, 3) >= 0) { // Scene // - Read BOOL groupCameras if (!baseFile->ReadBool(&groupCameras;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL groupLights if (!baseFile->ReadBool(&groupLights;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 6, 7) >= 0) { // Dialog // - Read BOOL explorerFold if (!baseFile->ReadBool(&explorerFold;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL actionsFold if (!baseFile->ReadBool(&actionsFold;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL prefsGeneralFold if (!baseFile->ReadBool(&prefsGeneralFold;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL prefsSceneFold if (!baseFile->ReadBool(&prefsSceneFold;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL prefsDialsFold if (!baseFile->ReadBool(&prefsDialsFold;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL prefsMatFold if (!baseFile->ReadBool(&prefsMatFold;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Materials // - Read BOOL useLuminance if (!baseFile->ReadBool(&useLuminance;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real illumDiffuseFalloff if (!baseFile->ReadReal(&illumDiffuseFalloff;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real illumDiffuseLevel if (!baseFile->ReadReal(&illumDiffuseLevel;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real illumRoughness if (!baseFile->ReadReal(&illumRoughness;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read LONG texturePreviewSize if (!baseFile->ReadLong((LONG* )&texturePreviewSize;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Luminance ChannelSampling Sampling[CHANNELSAMPLING_LUMINANCE] if (!baseFile->ReadBool(&(Sampling[CHANNELSAMPLING_LUMINANCE].use))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadLong(&(Sampling[CHANNELSAMPLING_LUMINANCE].sampling))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadReal(&(Sampling[CHANNELSAMPLING_LUMINANCE].blurOffset))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadReal(&(Sampling[CHANNELSAMPLING_LUMINANCE].blurScale))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 6, 8) >= 0) { // - Read BOOL handSpreadLimits if (!baseFile->ReadBool(&handSpreadLimits;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 7, 2) >= 0) { // - Read Filename externalApp if (!baseFile->ReadFilename(&externalApp;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 0, 7, 9) >= 0) { // - Read BOOL ignoreMatCase if (!baseFile->ReadBool(&ignoreMatCase;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 1, 1, 3) >= 0) { // - Read BOOL hideBanner if (!baseFile->ReadBool(&hideBanner;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 1, 3, 3) >= 0) { // - Read Vector ikColor if (!baseFile->ReadVector(&ikColor;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read LONG ikDisplay if (!baseFile->ReadLong(&ikDisplay;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read LONG ikOrient if (!baseFile->ReadLong(&ikOrient;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real ikRadius if (!baseFile->ReadReal(&ikRadius;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Real ikAspect if (!baseFile->ReadReal(&ikAspect;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 1, 4, 0) >= 0) { // - Read BOOL newStyleApply if (!baseFile->ReadBool(&new;StyleApply)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL autoSave if (!baseFile->ReadBool(&autoSave;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read LONG numRecentContent if (!baseFile->ReadLong(&numRecentContent;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read LONG numRecentScene if (!baseFile->ReadLong(&numRecentScene;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // Dialog // - Read BOOL recentFold if (!baseFile->ReadBool(&recentFold;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read BOOL favoritesFold if (!baseFile->ReadBool(&favoritesFold;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 1, 4, 3) >= 0) { // - Read BOOL autoThumbWidth if (!baseFile->ReadBool(&autoThumbWidth;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 1, 4, 4) >= 0) { // - Read BOOL autoThumbWidthFave if (!baseFile->ReadBool(&autoThumbWidthFave;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); // - Read Favorites Normal/Selected Color values if (!baseFile->ReadVector(&colorsFavorites;[0])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadVector(&colorsFavorites;[1])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadVector(&colorsFavorites;[2])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); if (!baseFile->ReadVector(&colorsFavorites;[3])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } if (CheckInterPoserVersion(&version;[0], 1, 5, 5) >= 0) { // - Read BOOL pngMethod if (!baseFile->ReadBool(&pngMethod;)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_READFILE_TEXT), baseFilename.GetString()); } // add new version values here (skip if they don't exist) baseFile->Close(); return TRUE; } // CMD: Save Settings to Prefs file //*---------------------------------------------------------------------------* BOOL Settings::SaveSettings(BaseFile* baseFile, const Filename& baseFilename, LONG rtCount, RuntimeItem* firstRTI, RuntimeItem* selected) //*---------------------------------------------------------------------------* { baseFile->Close(); // Open prefs.txt and write out Settings and Runtimes if (!baseFile->Open(baseFilename, GE_WRITE, FILE_NODIALOG)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_OPENFILE_TEXT), baseFilename.GetString()); // - Write UCHAR version[3] if (!baseFile->WriteBytes(&INTERPOSERPRO;_VERSION[0], 3)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.4.3 // General // - Write BOOL autoPrefs if (!baseFile->WriteBool(autoPrefs)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real objScaling if (!baseFile->WriteReal(objScaling)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real infiniteLightRadius if (!baseFile->WriteReal(infiniteLightRadius)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // Scene // - Write BOOL includeCameras if (!baseFile->WriteBool(includeCameras)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL includeLights if (!baseFile->WriteBool(includeLights)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL includeGround if (!baseFile->WriteBool(includeGround)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // Dials // - Write BOOL overrideMorphEdit if (!baseFile->WriteBool(overrideMorphEdit)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real morphEditMin if (!baseFile->WriteReal(morphEditMin)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real morphEditMax if (!baseFile->WriteReal(morphEditMax)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real morphEditStep if (!baseFile->WriteReal(morphEditStep)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // Materials // - Write BOOL useTMin if (!baseFile->WriteBool(useTMin)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL useReflection if (!baseFile->WriteBool(useReflection)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL useSpecularMode if (!baseFile->WriteBool(useSpecularMode)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL useIllumModel if (!baseFile->WriteBool(useIllumModel)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG specularMode if (!baseFile->WriteLong(specularMode)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG illumModel if (!baseFile->WriteLong(illumModel)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write ChannelSampling Sampling[6] for (INT i = 0; i < 6; ++i) { if (!baseFile->WriteBool(Sampling _.use)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteLong(Sampling _.sampling)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteReal(Sampling _.blurOffset)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteReal(Sampling _.blurScale)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); } // Displacement // - Write BOOL useDisplacement if (!baseFile->WriteBool(useDisplacement)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL heightAbsolute if (!baseFile->WriteBool(heightAbsolute)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG displacementType if (!baseFile->WriteLong(displacementType)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG subdivisionLevel if (!baseFile->WriteLong(subdivisionLevel)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL roundGeometry if (!baseFile->WriteBool(roundGeometry)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL roundContour if (!baseFile->WriteBool(roundContour)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL mapRoundedGeometry if (!baseFile->WriteBool(mapRoundedGeometry)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL mapResultingGeometry if (!baseFile->WriteBool(mapResultingGeometry)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL keepOriginalEdges if (!baseFile->WriteBool(keepOriginalEdges)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL bestDistribution if (!baseFile->WriteBool(bestDistribution)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Filename Project path if (!baseFile->WriteFilename(ProjectPath)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // Runtime Explorer // - Write Normal/Selected Color values if (!baseFile->WriteVector(colorsExplorer[0])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteVector(colorsExplorer[1])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteVector(colorsExplorer[2])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteVector(colorsExplorer[3])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteVector(colorsExplorer[4])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteVector(colorsExplorer[5])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG RuntimeExplorer Count if (!baseFile->WriteLong(rtCount)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write RuntimeExplorer paths for (RuntimeItem* rt = firstRTI; rt; rt = rt->GetNext()) { // - Write BOOL rt->flag&checked; if (!baseFile->WriteBool(rt->GetBit(RTFLAGS_CHECKED))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteFilename(rt->GetFilename())) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), rt->GetFilename().GetString()); } if (selected) { // - Write String lastRTEFolder if (!baseFile->WriteString(selected->GetPathString())) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); } else if (!baseFile->WriteString(String(""))) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.4.7 // - Write BOOL imageSearch if (!baseFile->WriteBool(imageSearch)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteBool(useMasterSlaves)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.4.8 if (!baseFile->WriteBool(clearSelection)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteBool(storeUndoLoad)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.4.9 // Dials // - Write BOOL overrideParmEdit if (!baseFile->WriteBool(overrideParmEdit)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real parmEditMin if (!baseFile->WriteReal(parmEditMin)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real parmEditMax if (!baseFile->WriteReal(parmEditMax)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real parmEditStep if (!baseFile->WriteReal(parmEditStep)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.5.8 // - Write BOOL logging if (!baseFile->WriteBool(logging)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.6.1 // Dials // - Write BOOL overrideTransEdit if (!baseFile->WriteBool(overrideTransEdit)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real transEditMin if (!baseFile->WriteReal(transEditMin)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real transEditMax if (!baseFile->WriteReal(transEditMax)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real transEditStep if (!baseFile->WriteReal(transEditStep)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.6.3 // - Write BOOL groupCameras if (!baseFile->WriteBool(groupCameras)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL groupLights if (!baseFile->WriteBool(groupLights)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.6.7 // Dialog // - Write BOOL explorerFold if (!baseFile->WriteBool(explorerFold)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL actionsFold if (!baseFile->WriteBool(actionsFold)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL prefsGeneralFold if (!baseFile->WriteBool(prefsGeneralFold)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL prefsSceneFold if (!baseFile->WriteBool(prefsSceneFold)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL prefsDialsFold if (!baseFile->WriteBool(prefsDialsFold)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL prefsMatFold if (!baseFile->WriteBool(prefsMatFold)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // Materials // - Write BOOL useLuminance if (!baseFile->WriteBool(useLuminance)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real illumDiffuseFalloff if (!baseFile->WriteReal(illumDiffuseFalloff)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real illumDiffuseLevel if (!baseFile->WriteReal(illumDiffuseLevel)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real illumRoughness if (!baseFile->WriteReal(illumRoughness)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG texturePreviewSize if (!baseFile->WriteLong(texturePreviewSize)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Luminance ChannelSampling Sampling[CHANNELSAMPLING_LUMINANCE] if (!baseFile->WriteBool(Sampling[CHANNELSAMPLING_LUMINANCE].use)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteLong(Sampling[CHANNELSAMPLING_LUMINANCE].sampling)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteReal(Sampling[CHANNELSAMPLING_LUMINANCE].blurOffset)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteReal(Sampling[CHANNELSAMPLING_LUMINANCE].blurScale)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.6.8 // - Write BOOL handSpreadLimits if (!baseFile->WriteBool(handSpreadLimits)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.7.2 // - Write Filename externalApp if (!baseFile->WriteFilename(externalApp)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v0.7.9 // - Write BOOL ignoreMatCase if (!baseFile->WriteBool(ignoreMatCase)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v1.1.3 // - Write BOOL hideBanner if (!baseFile->WriteBool(hideBanner)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v1.3.3 // - Write Vector ikColor if (!baseFile->WriteVector(ikColor)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG ikDisplay if (!baseFile->WriteLong(ikDisplay)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG ikOrient if (!baseFile->WriteLong(ikOrient)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real ikRadius if (!baseFile->WriteReal(ikRadius)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Real ikAspect if (!baseFile->WriteReal(ikAspect)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v1.4.0 // - Write BOOL newStyleApply if (!baseFile->WriteBool(newStyleApply)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL autoSave if (!baseFile->WriteBool(autoSave)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG numRecentContent if (!baseFile->WriteLong(numRecentContent)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write LONG numRecentScene if (!baseFile->WriteLong(numRecentScene)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL recentFold if (!baseFile->WriteBool(recentFold)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write BOOL favoritesFold if (!baseFile->WriteBool(favoritesFold)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v1.4.3 // - Write BOOL autoThumbWidth if (!baseFile->WriteBool(autoThumbWidth)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v1.4.4 // - Write BOOL autoThumbWidthFave if (!baseFile->WriteBool(autoThumbWidthFave)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // - Write Favorites Normal/Selected Color values if (!baseFile->WriteVector(colorsFavorites[0])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteVector(colorsFavorites[1])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteVector(colorsFavorites[2])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); if (!baseFile->WriteVector(colorsFavorites[3])) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); // v1.5.5 // - Write BOOL pngMethod if (!baseFile->WriteBool(pngMethod)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_WRITEFILE_TEXT), baseFilename.GetString()); baseFile->Close(); return TRUE; }
On 16/09/2007 at 07:02, xxxxxxxx wrote:
OK, I made certain progress. Here are my SavePreset() and LoadPreset() functions (shortened a bit).
First, there's SavePreset() :
static Bool SavePreset(BaseTag *tag, Filename fn) { BaseFile* PresetFile; PresetFile = BaseFile::Alloc(); if (!PresetFile) return FALSE; if (PresetFile->Open(fn, GE_WRITE, FILE_DIALOG, GE_MOTOROLA, MACTYPE_CINEMA, MACCREATOR_CINEMA)) { // Main Settings PresetFile->WriteBool(tag->GetData().GetBool(SCOOBYCAMEXP_ENABLED)); PresetFile->WriteReal(tag->GetData().GetReal(SCOOBYCAMEXP_MAINFACTOR)); PresetFile->Close(); return TRUE; } else { return FALSE; } }
The LoadPreset() looks almost similar:
static Bool LoadPreset(BaseTag *tag, Filename fn) { BaseFile* PresetFile; PresetFile = BaseFile::Alloc(); if (!PresetFile) return FALSE; if (PresetFile->Open(fn, GE_READ, FILE_IGNOREOPEN, GE_MOTOROLA, MACTYPE_CINEMA, MACCREATOR_CINEMA)) { BaseContainer *data = tag->GetDataInstance(); Bool BoolData; Real RealData; PresetFile->ReadBool(&BoolData;); data->SetBool(SCOOBYCAMEXP_ENABLED, BoolData); PresetFile->ReadReal(&RealData;); data->SetReal(SCOOBYCAMEXP_MAINFACTOR, RealData); PresetFile->Close(); } }
For Bool, Real and Vector data this works perfectly. But now I have TWO questions:
1. Isn't it a clumsy way to use those BoolData and RealData variables in the LoadPreset() function? Isn't there a more elegant solution to read the value and derectly put it into the BaseTag data?
2. How can I read and write a spline from the BaseTag's data? For example, I have such a Spline data:
SC_TargetBlendCurve = (SplineData* ) tag->GetDataInstance()->GetCustomDataType(SCOOBYCAMEXP_TARGET_BLENDSPLINE, CUSTOMDATATYPE_SPLINE);
How can I write SC_TargetBlendCurve into the file and also read it from the file & put it back to the Tag's DataInstance?
You see, I am still beginner in C++ ;-)
Thanks a lot for any help!!
Best regards & Greetings,
Jack
On 16/09/2007 at 13:38, xxxxxxxx wrote:
1. There is no way around this. You need to get at the value using a variable as an argument and then set the value using a variable. Since the ReadXXX() methods don't return the value (only success of reading), how else would you go about it? :)
2. You're going to need to dive into the resource folder and find the Spline resources for this custom data type in order to write that data out and read back in properly. You'll probably need to use a mix of GetDataIntance() and GetParameterI()/SetParameter() to get at the SplineData data.
On 16/09/2007 at 14:01, xxxxxxxx wrote:
1. OK, I supposed so. I'll survive it ;-)
2. I know how to access the SplineData, but do I really have to store all spline parameters separately? Is there no way to write a complete SplineData to a file?
I thought maybe WriteBytes(data, len) would help, but I am not sure if I am right and how to use it.
Regards,
Jack
On 16/09/2007 at 20:49, xxxxxxxx wrote:
Yes, you really do. ;) If you store the 'data' you won't get much as most of it is stored in BaseContainers - and remember that BaseContainers can contain BaseContainers and other data types not necessarily fully described. Now, you can read/write BaseContainers to a Hyperfile but not using BaseFile or any non-SDK method.
As noted in the docs, I'd avoid reading/writing byte blocks as much as possible. First, they are not platform-independent. If you are going to support both Windows and MacOS, you'll need to be extremely careful about byte-order (which system saved it and which is reading it?). I've done it in the past with limited success - sometimes the data was not read properly when going between systems.
Second, something you might want to contemplate considerably, is that the data in the SplineData is not guaranteed never to change. This is Maxon's and they might decide to add/remove/change/reorder data on a whim (for efficiency or new feature, perhaps) in the next release - and then where are you? See why this isn't a good idea? If the data block was yours and you had that control, it'd be more tenable.
On 17/09/2007 at 00:04, xxxxxxxx wrote:
OK, then I'll do that :-(
I was worried about how to determine which amount of data I have to read, since I do not know how many points a spline has, before I read them all. But I think, I'll just write the number of points and then read the appropriate number of values from the file.
Let's see how it works out. If I find a nice function for reading and writing spline data, I will post it here.
Greetings,
Jack
On 17/09/2007 at 00:27, xxxxxxxx wrote:
Saving the number of points in the spline and reading it in accordingly is a good practice. As you can see in my voluminous code example, this is exacly what I do for other variable numbers of elements. I store the count in a description resource and use that for the loop that reads in variable lengths of data elements.
The Hyperfile route may work here but it would be prudent to try it to see the results. Nonetheless, the second difficulty noting the volatile nature of the structures involved needs to be considered. Even supported structures like animation data has changed from R8.0 to R9.0 to R10.0 making compatability an issue when even stock plugin support is involved.
I agree that this requires more work and more consideration (I have 13 builds for one of my plugins which requires numerous preprocessor defines to placate the various methods and changes in the SDK over time). But the thing is not to only consider the current build but future expectations of change. At some point, something seemingly concrete changes (say Polygon* to CPolygon* as a nasty example of required code adaptation). Any parameters that can be described 'independently' so as to provide the least correspondence changes later will prove useful to continued support and easier updates.
So, basically, by going the more verbose route you should find it easier (believe it or not) to adapt the code to changes in the SDK just by making the appropriate preprocessor defines when you are supporting various versions.
On 17/09/2007 at 15:35, xxxxxxxx wrote:
I have made myself two nice little functions. I pass to them the BaseFile (already open for writing) and the SplineData.
This one writes SplineData into the BaseFile:
static Bool WriteSplineData(BaseFile *bf, SplineData *spd) { Real SplineRound; LONG KnotCount; LONG i; SplineData *sd = (SplineData* ) spd; if (!sd || !bf) return FALSE; SplineRound = sd->GetRound(); KnotCount = sd->GetKnotCount(); bf->WriteLong(KnotCount); bf->WriteReal(SplineRound); if (KnotCount > 0) { for (i=1; i<=KnotCount; i++) { bf->WriteVector(sd->GetKnots() _.vPos); } } return TRUE; }
And this one for reading the data from a BaseFile:
static Bool ReadSplineData(BaseFile *bf, SplineData *spd) { Real SplineRound; LONG KnotCount; LONG i; Vector VectorData; SplineData *sd = (SplineData* ) spd; if (!sd || !bf) return FALSE; bf->ReadLong(&KnotCount;); bf->ReadReal(&SplineRound;); sd->DeleteAllPoints(); sd->SetRound(SplineRound); if (KnotCount > 0) { for (i=1; i<=KnotCount; i++) { bf->ReadVector(&VectorData;); sd->InsertKnot(VectorData.x, VectorData.y); } } return TRUE; }
Best regards,
Jack
