On 13/09/2007 at 14:58, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.5 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hello to everybody.
I'm searching for a solution... a simple thing for you but not for me... by the way... I run an animation in C4D and I would like to store data produced by the COFFEE_Script attached (data visible in the c4Dconsole). I would like to store them in a unique list and save this "data_list" as a file ascii in a specifiable position in HardDisk. Pratically i need to play animation and store all the running data visible by "println(MatriceTotale);" to an unique ascii data list" How can I do? The script: Create a cube in c4d... add this coffee script... animate the cube rotation... look at c4d console... i need to store these data... main(doc,op) { var obj = doc->FindObject("Cube"); var matrix = obj->GetMg(); var globalRot = matrix->GetHPB(); var stringa = stradd("x ",tostring(globalRot)," items."); // Rotazione HP var posizione = 3; var lunghezza = 8; // Rotazione HB var posizione1 = 12; var lunghezza1 = 8; var MatriceTotale = stradd("H", strmid(stringa,posizione,lunghezza), " P",strmid(stringa,posizione1,lunghezza1));
println(MatriceTotale); } Thanks in advance
On 15/09/2007 at 14:13, xxxxxxxx wrote:
Nothig is going the way I hoped... Please... need SOME HELP! It isn't a simple stupid test! There isn't a really easy way to explain how much important should be this help.. Is it at least possible to do it?? Some "Guru meditation" is needed.. Thx
On 16/09/2007 at 06:04, xxxxxxxx wrote:
hi buzz,
for that kind of stuff I use this set-up. It allows you to append parameters to a text-file per frame.
hope this helps, frank.
On 17/09/2007 at 01:55, xxxxxxxx wrote:
Loading and saving files from within COFFEE expressions is forbidden. You have to write a script or try the setup Fank has posted, although it is not recommended to write or load files from within XPresso expressions.
On 17/09/2007 at 12:38, xxxxxxxx wrote:
Hi FrankBerg-Matthias,
Tnx for tips setup posted seem to work wery well.. is very interesting this solution.. now I fell optimistic really.. many thanks This evening I turn my attention to a little LAST problem.. data stored aren't separated by "carriage return" so stored code look like a single data_block!
Some possible solutions?
Best regards Chris
On 17/09/2007 at 14:58, xxxxxxxx wrote:
No sooner said than done.. really easy.. Thanks for everything cheers Chris
On 24/04/2009 at 07:31, xxxxxxxx wrote:
How did you solve that problem with the single block versus single lines or a delimiter? I have the same problem now... Cheers Rainer
On 24/04/2009 at 07:42, xxxxxxxx wrote:
Quote: _although it is not recommended to write or load files from within XPresso expressions. > > * * * _
this script was written in a time where I just started to write scripts so I forgive myself
On 24/04/2009 at 08:55, xxxxxxxx wrote:
Lemo: Take a look at the sixth post:
http://py4d.xpresso24.com/wordpress/sdk/?wpforumaction=viewtopic&t;=34.0#4
